2012 wr450f bearing locked up
32 replies to this topic
  • mattpann
Posted October 19, 2014 - 09:38 PM
#21
Has anyone bought parts from international Moto parts it seems they are a lot cheaper than in Australia
  • mattpann
Posted November 21, 2014 - 04:06 AM
#22
Just finished putting it back together new crank assembly and crank bearings and it's going good
  • revelc
Posted November 21, 2014 - 06:05 AM
#23
How much did it end up setting you back?
  • Krannie McKranface
Posted November 21, 2014 - 06:22 AM
#24
I have the under at  $1685.00
  • mattpann
Posted November 22, 2014 - 12:18 AM
#25
The parts cost me 900aud with a big gun Eco slip on not to bad really. I got the parts from motoparts In hollywood online highly recommend for pricing. I used all genuine Yamaha parts as well.
Edited by mattpann, November 22, 2014 - 12:29 AM.
  • mattpann
Posted December 16, 2014 - 12:07 AM
#26
I just pressed the crank apart man all that was left was the needle rollers. The bearing cage totally gone not even a shard of it to be seen except the piece stuck in the oil journal.
  • Chaconne
Posted December 16, 2014 - 05:15 PM
#27
Wow. Not good.
  • mch
Posted December 16, 2014 - 08:45 PM
#28
What kind of oil did you run in it?
  • mattpann
Posted December 16, 2014 - 08:46 PM
#29
I was using belrays thumper oil
  • mch
Posted December 17, 2014 - 07:03 AM
#30
Weird you had that kind of failure with such low miles, and quality oil.  Perhaps oil pump failure?  Make sure you change that out too.
  • mattpann
Posted December 19, 2014 - 05:54 PM
#31
Oil pump was fine
  • cubera
Posted December 22, 2014 - 10:02 AM
#32
Hi all
I found the problem and am not happy.
Turns out the bottom end bearing is seized. I know what you all are thinking lack of oil.
I have change the oil in this bike 10 times in 2500km and the bottom end was wet as when I pulled it apart. I am thinking it had a problem from new.
Now I have to wait until I have enough money to replace the bottom end as I've just had open heart surgery 6 months ago and haven't worked since.
Just my luck I guess.
Thanks
Glad you got it all fixed and up and going again. I think you're right about this being a problem from the factory but it's a rare problem on a Yamaha. I just took apart the clutch on my 2013 and it's totally roached. Basket and inner hub are badly notched and the surfaces on the basket and pressure plate are grooved. I'll take pictures of it all when I get the parts in and replace them. It's a great idea to get a magnetic plug. That's exactly what I was thinking when I saw the damaged parts.
Edited by cubera, December 22, 2014 - 10:13 AM.
  • mattpann
Posted December 22, 2014 - 08:37 PM
#33
My clutch was really good no signs of any ware at all
