'03 wr450 one way assembly help!?!
7 replies to this topic
  • Ogzer707
Posted October 05, 2014 - 09:31 AM
I've been having starter issues. Did the '04 starter gear upgrade. Bought a new ricks custom starter. Still grinding noise. Took out flywheel to look at starter clutch and one way assembly. IN my manual it says counterclockwise it should engage most of the time it does. Not all the time though and I noticed a flat spot in the assembly. See picture. Will this cause all my damn starting issues???
Edited by Ogzer707, October 05, 2014 - 09:55 AM.
  • GuyGraham
Posted October 05, 2014 - 09:42 AM
all of the rollers or just the one?
if one should be ok, but if all of them, then its scrap
  • Ogzer707
Posted October 05, 2014 - 09:53 AM
Yeah it's just the one. I'm still trying to find out why my assembly doesn't engage all the time. It's the only visible damage that I could find. Thanks
  • GuyGraham
Posted October 05, 2014 - 10:10 AM
If its not engaging everytime when you try rotating it counter clockwise by hand then its got a problem, whether its visible or not
Whats the starter gear surface like where the rollers engage - scored / damaged?
This surface needs to be unmarked
Edited by GuyGraham, October 05, 2014 - 10:36 AM.
  • orangyktmthing
Posted October 05, 2014 - 10:11 AM
It never would hurt to replace the bearing assy.
  • Ogzer707
Posted October 05, 2014 - 10:19 AM
Thanks for the help fellas. So how do you remove the bearing housing from flywheel rotor?
  • GuyGraham
Posted October 05, 2014 - 10:37 AM
Don't think you can replace the 'bearing' assy out of them. Its sold as a complete unit if it needs replacing
part number 5TJ155900000
There's 6 bolts which hold it to the back of the rotor
Edited by GuyGraham, October 05, 2014 - 10:44 AM.
  • Ogzer707
Posted October 05, 2014 - 10:49 AM
Thanks for your help! Bearings aren't looking too good. Ima order a new assembly. Thanks again for the help
