06-09 YZ450f electric fan installation?
7 replies to this topic
  • War_IS_the_Answer
Posted October 02, 2014 - 03:34 PM
Any ideas?
Posted October 02, 2014 - 03:40 PM
...about mounting them, or powering them?
There is NO surplus electricity to do anything with on the '03-'09 YZ450; zero.  The stators are smaller than the gas cap, and intended only to operate the ignition.  But, you can run small DC computer chassis fans off a single 9V for up to 2 hours straight.  Put a switch in so you can leave them off until they matter, and you'll be set.
  • MrFreez82
Posted October 04, 2014 - 04:24 PM
I did it with my YZ426
http://www.thumperta...an-on-dirtbike/
  • mdsharon
Posted October 06, 2014 - 12:10 PM
http://www.thumperta...dirtbike/Should not overheat, run blue ice and never let idle for more than a couple of minutes never have had  a problem. Even with smashed radiators. Maybe you have a different problem, if you really want to put in high flow water pump in..
  • MrFreez82
Posted October 06, 2014 - 04:13 PM
Yes   however when waiting after freinds, I tend to not stop the engin since it's a @@@#$% to restart when very hot
  • mdsharon
Posted October 07, 2014 - 07:13 AM
I would check the valves, If they are right it should start in one kick ares all do 06-09 yzs
  • Hoosier-Daddy
Posted October 10, 2014 - 05:37 PM
I have ridden my bike slow.. alot. Hit single track at low speed. Spent a lot of time on the clutch before I got it geared lower and heavy flywheel installed. Stock motor with engine ice and have never experienced the need for a fan.
  • Mtrain730
Posted October 10, 2014 - 06:10 PM
Same here went out with a friend who was on a bayou 250 he was creeping if I went any slower I would have tipped over while I did feel my legs getting a little warm it didn't boil over. After that I don't see a need to even bother with a fan. Mine is 2012 by the way not sure if that makes a difference.
  • 10 replies
  • Hot  30 replies
  • 0 replies
