Does your bike pop on decel? Easy fix...
2 replies to this topic
  • yuppivore
Posted October 01, 2014 - 11:26 PM
Hi guys, I've just spent the last few days trying to get rid of the popping on decel from a 05 WR450F. And I can't believe how simple the fix was so I want to share it for anyone else suffering like I was.
Basically, the first thing I would do before you go stuffing around with the jetting, or hunting and plugging air leaks in the exhaust is just to check your ACV. Mine must not have been seated properly - even though it looked like it was when I pulled it apart. If you don't know what it is:
http://www.thumperfaq.com/acv.htm
Just pull the cover off (watch for the spring) and check the condition of the rubber for leaks and then re-install and see how it goes. For me, it fixed it straight away. Make sure the pointy bit goes in towards the carb, if you were wondering.
I pulled the cover off accidentally while man-handling the carb while re-jetting following an exhaust replacement. When I pulled it off again it looked fine but after reinstalling it - the problem was completely gone.
  • Silent Echo
Posted October 02, 2014 - 12:23 AM
Hmm. Interesting. If they cover is open, then it let's too much air in and it leans out the mixture considerably... Good to know! Nice find
  • GASKICKER
Posted October 02, 2014 - 08:17 AM
Good idea, i just adjusted the fuel screw and that fixed the decel popping.
