Yz426 with 03 yz450 sleeve and head. Possible?
Yamaha YZ426F
5 replies to this topic
  • MattyDubz426f
Posted October 01, 2014 - 09:03 AM
Yz426 yz450 bigbore bolton 03yz450 stroker
Posted October 01, 2014 - 09:25 AM
Is there a question?
  • MattyDubz426f
Posted October 01, 2014 - 10:19 AM
Ok.... Is it possible to put the sleeve and head off of a 03yz450. Onto the yz426 motor. For big bore swap with no machining needed. And what timing chain to use
Posted October 01, 2014 - 12:53 PM
As I understand it, it's possible to adapt the gen1 450 cylinder and head onto a 426, but the bore is the same 95mm that the 426 is already, so even after all that work and expense, it won't be any bigger than it is now.
  • MattyDubz426f
Posted October 01, 2014 - 12:58 PM
Is the stroke longer on a 450 than the 426??? Could that be a power advantage. Leaving the 426 lowerend and putting the 450 top end and piston n rod.
Posted October 01, 2014 - 02:48 PM
...would do nothing.  The radial distance between the crank shaft and crank pin (where the rod goes) is what controls the stroke, not the rod length.  And no, a 450 crank will NOT fit a 426.
YZ426F No Start by YZ426Supermoto
  • Hot  33 replies
2001 Yamaha YZ426F project by 98yota
  • Hot  77 replies
Yz426f by mideast209
  • 13 replies
2001 YZ426F Won't Start by buck424moto
  • 11 replies
02 WR426 Ticking when moved around in neutral w engine off by Alwaats
Dirt Bike   Make / Model Specific   Yamaha   WR 400/426/450
