WR450 cracked case
1 reply to this topic
  • pugsley8285
Posted September 23, 2014 - 03:22 AM
I think there may already be a topic on this but i was unable to find it. I recently bought a 2004 WR450, after several attempts at kick starting (the engine started) I noticed the kick starter had not completely retracted. So to cut a long story short It appears that a section of the engine case has cracked out and it appears the kick start mechanism is broken A few questions
1. Is this common with older model WR's
2. Is the cracked section repairable i.e. welding of the case
3. If not repairable is a new case required
4. Does the whole motor need to be removed regardless
As I'm very novice any help would be great
  • sosycz
Posted September 23, 2014 - 04:12 AM
Pictures would be helpful. Are you sure that the case is cracked? Isn't it the cover?
