wr450f start/kiill switch
4 replies to this topic
  • fitzhugh
Posted September 19, 2014 - 02:29 PM
my wr450f ignition switch activates the starter. when I hit the kill switch the starter still tries to start the bike.  anybody have this issue?
  • stevethe
Posted September 19, 2014 - 06:37 PM
I don't know of anybody with that issue. Sounds like you have some wires crossed or you are missing the ground somewhere.
  • Krannie McKranface
Posted September 19, 2014 - 08:55 PM
Can't comprehend your description
  • cassinova90
Posted September 21, 2014 - 04:09 PM
I would say broken wire around the headstock , either that or someone has reversed the start and stop plugs ? Either way not normal . Best bet would be to remove the witch and check with a multimeter on the ohms range.
  • DrFeelGood
Posted September 22, 2014 - 05:54 PM
So, when you push the ignition on button (next to the display) the starter starts whirling over?
Sounds like your starter button next to the throttle is busted.
