Can't adjust MCCT
Take the top cover off the motor so you can see the cams and cam chain.  Adjust the cam chain tension to take the slack out to the rear run as you turn the motor forward and the cams start to open the EX valves.  Turn the motor over several times to assure all the slop is out of the chain.
  • Like 2
