speedo eliminator
7 replies to this topic
  • jarabe1
Posted September 08, 2014 - 06:28 PM
Hi guys I just bought a Vapor and I want to eliminate the stock wheel odometer. I've been looking on ebay and rocky mount with no luck. Do you guys have the link where I can get one?
thanks in advance
  • cracker please
Posted September 08, 2014 - 08:35 PM
http://appliedrace.c...4806d8c4bb1f528
I got that one.  Flatland racing makes one too.  Probably a couple other ones out there.  You could also just cut the cable off, I think there's a little cap that comes with the vapor to cover it up.
  • DRZ04
Posted September 10, 2014 - 08:39 PM
I just bought a Vapor from RCMC last week. = Trail Tech Vapor Speedometer/Tachometer - 2011 Yamaha WR450F part # 1152320004 $116.69 with free shipping.
I removed the stock speedo gear & wiring all the way up to the speedo, but you will need to install a spacer to take up the room, but I installed a set of 17" SM wheels. I sure would not want to cut the wires on the stock unit.
Edited by DRZ04, September 10, 2014 - 08:44 PM.
  • mch
Posted September 10, 2014 - 09:46 PM
I just ditched my speedo cable recently because the cable was damaged and not sure what the deal was, but the speedo was reading a speed about double than actual.  I'm cruising down a desert road at about 40mph, 1 hand on the bar, and motor not revving too much and it's saying I was going 93mph.
That being said, I no longer needed the cable so cutting it wasn't a big deal.  What I wasn't expecting was that the Flatland racing spacer / wheel bearing cover requires that you pull the seal off of the original speedo-spacer-bearing cover and stick it on the Flatland racing unit.  I tried prying it out with a screwdriver, etc., but wasn't having much luck.  I finally stuck it in a vice and tweaked the housing until it deformed and then I got the seal out.  I actually have a new speedo cable in a box, but think it was like $100+ if I want to get it working again or if I want to sell the dirt bike.
Edited by mch, September 10, 2014 - 10:39 PM.
  • MidlifeCrisisGuy
Posted September 10, 2014 - 10:34 PM
I just ditched my speedo cable recently because the cable was damaged and not sure what the deal was, but the speedo was reading a speed about double than actual.  I'm cruisind down a desert road at about 40mph, 1 hand on the bar, and motor not revving too much and it's saying I was going 93mph.
I run the flatland unit as well.  I too had trouble getting the seal out of the stocker.   I can't remember how I did it.  Just wanted to say that you weren't alone.
  • JVP
Posted September 11, 2014 - 09:12 AM
My two cents.. Trail Tech stuff is crap. They are cheaply made from China and don't hold up for dirt riding.  You are better off using a GPS system to gage your mileage and speed.  However, if you are going that route Barnum Pro Products makes a nice billet aluminum odometer spacer to replace the stock front wheel spacer for the WR's.  The only issue with Barnum's is I think they may be out of business, so you will have to do some research to find one.
  • DRZ04
Posted September 11, 2014 - 09:07 PM
My reference was for my 2013 WR450F & it is an electrical wire from the wheel adapter to the speedo not a cable. The vapor I have on my DRZ435 came with a small rubber plug that fits in the whole the cable inserts into.
  • jarabe1
Posted September 17, 2014 - 06:22 PM
Thank you guys, I just cut the cable off ;)
