Difficulty Shifting 2011 YZ450
5 replies to this topic
  • JLB943
Posted September 08, 2014 - 04:38 AM
I am having difficulty shifting 2011 YZ450 during riding. I attempt to shift with my foot and at times it does not go into gear or it is very vague whether the gear change has occurred. What would this be a sign of ? Bent shift fork?
What would be a way to test whether there is a problem or it is an issue with my technique?
  • YamaLink
Posted September 08, 2014 - 05:39 AM
One possibility: when was last time oil was changed?
Or: is the actual shift lever bent in just a little bit causing the boot to not get positive engagement?
  • JLB943
Posted September 08, 2014 - 10:09 AM
Oil was changed before the last ride so prob 1-2 hrs ago. I will take a look at the shift lever. I replaced the stock shifter with a longer hammerhead version. I tightened it previously when I noticed it was slightly loose.
  • mikedabike
Posted September 08, 2014 - 11:22 AM
Loose shift lever will cause this and they tend to loosen up occasionally.
  • torkd14
Posted September 08, 2014 - 04:41 PM
Those hammerhead levers seem to loosen a lot quicker. I had to grind the groove bigger after one season to allow for more tightening space.
  • JLB943
Posted September 08, 2014 - 06:09 PM
I will take a look at the shifter and verify that it is completely tight first.
  • Hot  50 replies
  • Hot  47 replies
  • Hot  113 replies
