14 yz 450 in the woods
6 replies to this topic
  • Goforaride
Posted September 07, 2014 - 02:28 PM
I'm considering doing a race at the end of the month. The course is a combination of mx track, woods and man made obstacles. This is a once a year race so I'm not going to revalve for it. What I need is some advice on what clicker adjustments to make. My concern is dealing with roots. Lots of roots.
Edited by Goforaride, September 07, 2014 - 02:31 PM.
Posted September 08, 2014 - 06:19 AM
For woods with an MX suspension set up open the compression adjusters up to the limit, then tighten them down as necessary.
  • Goforaride
Posted September 08, 2014 - 01:29 PM
would i pretty much leave the rebound as is? Fir the rear should i focus in hs or ls compression?
Posted September 09, 2014 - 06:35 AM
Both.  You want as much compliance as you can get away with from the compression.  Add more back as it becomes necessary to deal with bottoming, etc.  The rebound needs to be loose enough to return the wheel quickly without spring-boarding off obstacles.
  • YamaLink
Posted September 09, 2014 - 12:16 PM
Is it possible to pre-ride and get a better idea?
  • Goforaride
Posted September 09, 2014 - 01:51 PM
nope. And all the trails are closed due to fire season. Cant even ride except in the dunes. Likely won't get to ride any dirt before the event. Likely just gonna leave her be and suffer through the beating
  • yukondood
Posted September 10, 2014 - 06:40 AM
reduce your tire pressure to 10 or throw in tubes and reduce to 6-8, this will help you roll over roots, and obstacles.  Detune for less arm rip and have fun.  We too have some hare scrambles that I run my 14 yz 450 in.  It is way too much bike but fun
  • 9 replies
  • Hot  50 replies
  • Hot  36 replies
  • 0 replies
