Fork oil change
9 replies to this topic
  • stevethe
Posted September 06, 2014 - 07:44 AM
Ever since I put extra fork guards on and run fork skins I haven't had a fork seal leak. So I am feeling guilty about not changing the oil. I have heard of removing the forks and leaving them upside down to drain the old oil out. Anyone do it this way.
Edited by stevethe, September 06, 2014 - 05:47 PM.
  • Krannie McKranface
Posted September 06, 2014 - 11:03 AM
If you have 2011 and before, you can do that
If you have 2012 and later, you must pump the oil out of the inner chamber, and double bleed the chamber and fork upon re-assembly
  • stevethe
Posted September 06, 2014 - 05:48 PM
Thanks she's the early ones. So it should be easy.
Posted September 06, 2014 - 06:16 PM
Yup
Put a phillips screwdriver in the gas tank vent to plug it, Hang the bike upside down from the rafters, loosen the top triple clamp, and remove the fork caps.
Fast and easy.
  • stevethe
Posted September 06, 2014 - 06:18 PM
Yup
Fast and easy.
Hum how come I never tried that check for weak rafters.
Posted September 06, 2014 - 06:31 PM
Use a sky hook
  • jjcoffman
Posted September 06, 2014 - 06:55 PM
Yup
Fast and easy.
omg this... :goofy:
Posted September 06, 2014 - 07:33 PM
What?
  • stevethe
Posted September 07, 2014 - 05:06 AM
ON IT.
Posted September 07, 2014 - 12:50 PM
TOLD YOU SO
