XR600 Crankcase drain plug
5 replies to this topic
  • RocaFellaRanger
Posted January 28, 2004 - 06:09 PM
I went to change the oil on my XR600 today, and found that the crankcase drain bolt is stuck. I messed up the bolt head a little bit, but stopped before I completely ruined it. Anybody have any suggestions as getting it off so I can complete the oil change? If not, I guess it goes to ECC. :) Thanks.
  • gfergtr74
Posted January 28, 2004 - 07:41 PM
Try applying some heat to the area around the bolt with a small butane torch.
  • TimBrp
Posted January 29, 2004 - 04:49 AM
It's stuck? As in too tight and starting to strip? A trick I've used a number of times with button-head bolts and of the like is to spray some penetrant oil on it and file down to opposite sides(you'll need a new bolt) then once filed grab it tightly with some needlenose vicegrips and wallah! It comes right off.
  • Trasher
Posted January 29, 2004 - 11:27 AM
Take a punch and tap on it first before stripping it further. That might loosen it up for you
  • RocaFellaRanger
Posted January 29, 2004 - 12:18 PM
The torch finally did the trick-what a pain. Now I need to get a new drain bolt.
  • Trasher
Posted January 29, 2004 - 02:35 PM
Great! At least you finally removed it
  • Hot  35 replies
  • 17 replies
  • Hot  29 replies
Washington
  • Hot  32 replies
  • 4 replies
