YZ 450 2014 LOOSE FRONT END
Yamaha YZ450F 2014 Suspension
141 replies to this topic
  • GHILL28
Posted February 13, 2015 - 10:11 AM
Right, I have tried that a bit, and have always ended up back at R 8 (gone out to R 12).  The lighter front end on this thing likes a little bit tighter rebound to "stick" in ruts it seems.  The faster rebound made it more nervous over braking and accel chop as well.  Normally on KYB stuff I'm running R 12, but this chassis is different in a lot of ways.
  • JS264
Posted February 13, 2015 - 04:56 PM
You got .51 fork springs Ghill?
  • GHILL28
Posted February 13, 2015 - 05:34 PM
.50kg, stock 2014 springs, flipped bleed stack, float .2, 335cc
  • JS264
Posted February 13, 2015 - 07:44 PM
Tighten that float up to .1mm.
I just poked in some DRD engine relocation collars tonight, I'll try to get to the arena in the next few days and see if i notice anything...
  • yzUSMCf
Posted February 13, 2015 - 07:47 PM
I'd like to see what you think. I just got some 2015 motor mounts . Aparently they help a good bit.
  • JS264
Posted February 13, 2015 - 07:48 PM
I installed the 15 mounts a while back. Small but good improvement.
  • yzUSMCf
Posted February 13, 2015 - 07:49 PM
I'm exited
  • rk8950
Posted February 13, 2015 - 09:04 PM
I put them and the new engine mounts in mine a while back, I could tell a difference.
  • Envisage
Posted February 14, 2015 - 05:00 AM
What difference did you notice ?
This on yr 14 model ?
  • GHILL28
Posted February 14, 2015 - 06:49 AM
I did the same 15 mounts. Seemed to hook better on choppy flat corners.
  • GHILL28
Posted February 14, 2015 - 07:15 AM
Yeah I'm either going to put the bleed stack back with some reduced bleed, tighten the float, or add another 32 in the base stack I think.
  • Envisage
Posted February 14, 2015 - 07:05 PM
Have to agree there, tried mine at 12, but its too fast. Had it at 8, (rough sand track) felt dull & a bit too slow, think 9 is about right.
Like to hear any suggestions on what i need to do the take that harshness out of the stroke ?
  • MESSMAKER
Posted February 16, 2015 - 07:22 AM
Whenever my forks started to feel harsh the needed to be bled. I put the motion pro micro bleeders on and it makes it much easier.
RM   https://www.rockymou...ro-Fork-Bleeder
  • Tiago
Posted February 17, 2015 - 11:13 AM
So far i like my setup and feel the front planted on the ground while cornering into ruts and still pretty easy on straights to pull the front to clear bumps at high speed.
Front rebound and compression 8 clicks, 110mm sag and standard rear specs. At hard terrain, the front suspension it bottoms when i overjump the landing on bigger jumps but other than that it feels pretty spot on. My weight with gear is 210lbs.
Clamps 15mm away from top forks. Handlebars mounts on front on clamps and rotated backwards. Almost perfect aligned with the center of the forks. And since i have 6ft of height it has fastway pegs on lowboy position and 0.8inch handlbars mounts height over stock.
I believe that the loose front it has more to do with the rider body position than suspension setup. Since i feel pretty confort and i'm almost straight while riding standup, it is easy to me to sit over the fuel tank while entering into corners, giving load to front end and grip.
Edited by Tiago, February 17, 2015 - 11:35 AM.
  • GHILL28
Posted February 17, 2015 - 12:53 PM
Sounds pretty much my exact setup.  110 sag, forks pulled up to first line, Fastway pegs, forward bars, 6' rider, 185# + whatever gear I'm carrying.
The front has a bit of a wobble to it in fast sandwashes.  I'm thinking the bleed stack needs to go back in, with maybe 1 or 2 face shims put in the back in the passive part of the bleed stack.  The weird thing is that when I stand and get over the front with my elbows out, the wobbling is greatly reduced.  This chassis is so strange.  Good, but strange.
I don't know that I liked having the forks pulled up in the clamps.  I made that change the last time and it didn't seem to offer the usual better turn-in that I expect when doing that.  It did seem to twist/push more coming into loose corners however.
JS264, are you still running the bleed stack in your forks?  Have you tried flipping it?
  • JS264
Posted February 18, 2015 - 08:35 PM
Got a lot of info to add to this thread, keep leaving my computer at work though. Hopefully I'll have a post with something to chew on for tomorrow evening.
  • GHILL28
Posted February 23, 2015 - 08:50 AM
JS, still curious to hear your input!
  • JS264
Posted March 07, 2015 - 05:02 PM
I know I've been slacking on that. Soon
  • GHILL28
Posted March 14, 2015 - 06:06 PM
Still waiting to hear the input on the valving.
I'm at the point where I'm about to change mine up a bit.  I've got the shock pretty well sorted, now the forks need some attention.  Either tighter float/lighter mid, add the bleed stack back in, or go stiffer on the BV.  The "sting" is what I'm trying to tune out, and my feeling is that something in the valving is hitting a harsh transition somewhere.  On certain high speed impacts it's very nice and smooth and still supportive.  On low speed rollers, it's great.  The occasional square edge at high speeds, hardpack chop and braking bumps, especially on downhills, seems to transmit a LOT to the hands and result in unwanted chassis motion.  I suspect it's just getting down into the harsh part of the stroke.
I'm thinking a .15 foat, tapered MV stack with 3x20, clamping on a 10mm, and the bleed stack back in with 1 or 2 face shims removed.  Stock BV otherwise.
Very few people go stiffer on these, so I'm curious to see what the results have been.  This is a mix of recreational MX, and fast aggressive offroad.  Rocky, whoopy, fast, dry terrain.
  • GHILL28
Posted March 29, 2015 - 10:46 PM
Went to .1mm float, tapered mid as described above, no bleed stack, stock BV, 335cc oil.  Really good composure through soft stuff and downhills and braking and holding up against fast steep takeoffs.  Definitely beats me up on the big hardpack square edge chop though.  Our stuff here is a mix of sandy and concrete-style hardpack.
Not sure if I want to go to a crossover in the BV?  Smaller clamp shim?  Less face shims?
Still can't quite pinpoint where the abrupt mid-stroke and square edge harshness in this fork comes from.  I guess it's gotta be the mega heavy BV stack, but that's also what seems to give it a lot of support.
