Nut on Triple Clamp
4 replies to this topic
  • DPW
Posted January 24, 2002 - 09:11 AM
What size is the nut on the top of the triple clamp, 30mm ???
  • Guest_Guest_*
Posted January 24, 2002 - 09:27 AM
It uses the Japanese wrench called the "fitall"
crecent wrench!!!! :)
  • motoman393
Posted January 24, 2002 - 09:39 AM
yes it is 30mm
  • Shawn_Mc
Posted January 25, 2002 - 01:32 PM
Remember to have at least one set of the pinch bolts loose, either tops or bottoms when sinch down the big stem nut on the triple clamp. The best way is acutally the bottoms that way the tops dont tend to twist while ya crank on it. :) now get like the red guy and git after it and get'r tight!
  • DPW
Posted January 25, 2002 - 03:33 PM
Good point Shawn, I'm glad you mentioned that.
Thumpin', I thought about the Japanese wrench , but that's one nut I want to make sure is torqued down.
