YZ450 rear brake clearance?
2 replies to this topic
  • Howat
Posted August 22, 2014 - 09:28 AM
So, broke my 09 yz450f oem rear brake lever. I run a GYTR clutch cover witch is the same as a Henson cover. Every aftermarket rear brake lever I try will not clear the clutch cover. The levers look the same as the oem one but it's like I need a longer step bolt to gain the right clearance. I've tried to shim the bolt but no go.
Any suggestions?
  • Hoosier-Daddy
Posted August 22, 2014 - 02:34 PM
I put my stock one in a vice and heated it up and bent it back after a log got ahold of it.
  • Howat
Posted August 22, 2014 - 05:27 PM
I did that and am using it at the moment but I just don't understand why the stock lever will work but hammer head, torq1, claim they fit but not so much.
Motocross
  • Hot  491 replies
  • 0 replies
  • 9 replies
  • Hot  47 replies
