2010 YZ450F no spark after rebuild
2 replies to this topic
  • Jmont31
Posted August 22, 2014 - 05:45 AM
A few weeks ago I put the chain on my 2010 yz450f through the case. So I took the motor out and bought a new case, piston, rings, gasket and seals and brought it to a well know mechanic that did awesome job. I got the motor back in and put everything exactly the way it was, I've been through everything 100 times. I went through the entire ignition system,  tested the kill switch, the coil primary and secondary side, and the stator, still no spark. I'm stuck I don't know what to do.
  • m-schroeder
Posted August 27, 2014 - 11:41 PM
Hey, have you solved your problem yet? Have you checked the flywheel? I have a similar problem at the moment. I put a new timing chain on and it wouldn't start anymore. I checked just about everything and then found out that the flywheel is damaged. ImageUploadedByThumper Talk1409211681.994641.jpg
  • Jmont31
Posted January 23, 2015 - 06:42 AM
Yes I did. Sorry for the late reply. It ended up being something stupid. I had the kill switch plugged into the position sensor, some how. What happened to your fly wheel?
  • 10 replies
  • Hot  47 replies
  • Hot  30 replies
1998 yz400f will not idle. by trolley
  • Hot  32 replies
  • Hot  38 replies
