Let's talk about Pro's & Con's of Hotcams.
Brand Hot Cams
24 replies to this topic
  • stevethe
Posted August 22, 2014 - 06:22 AM
#21
No the length of the pin in the first picture is correct. That's whats in the bike now and works perfect. :thumbsup:
You should just be able to look at it without even measuring. Shim it and go. If you really want some more performance put a little more compression on the piston cams love it.
Edited by stevethe, August 22, 2014 - 06:32 AM.
  • flyandride
Posted August 22, 2014 - 04:14 PM
#22
I've got Hotcams stage 1 cams in my 09 WR4450F and have had no trouble.  I replaced the stock cams because the auto decompression was not working right.  I could not find stage 2, but for the riding I do stage 1 is probably the way to go.  I've also used Hotcams stage 1 in a WR250F with no problems.
  • underground-mpyre
Posted August 23, 2014 - 02:41 AM
#23
That is great to hear assures my desire to fix the needless starting sequence. It will be done soon. But as it sits, without the auto-decomp it is a chore to ride and keeping it running.
  • KennyMc
Posted August 24, 2014 - 08:26 AM
#24
The issue I had was they installed the wrong decomp pin in the cam. A "philosophical" discussion about this not being a "race part" issue and more of a "lazy assed" employee, netted me a front and rear wheel bearing set and a front fork rebuild kit from there sister company Pivot Works. Have used the bearing set but not the front fork kit as I have sold the stock WR forks. Anyone want to use the kit? Open cartridge forks.
  • underground-mpyre
Posted August 25, 2014 - 05:42 AM
#25
I will take them. My forks just started leaking.
