Exhaust Pea-shooter
7 replies to this topic
  • MANIAC998
Posted August 19, 2014 - 01:46 AM
I've got an upcoming ride in Calabogie, Ontario, and those guys are strict on sound! I've purchased a used '06 WR450, that the previous owner had removed the stock Pea-shooter exhaust tip, so now I'm in the market to find one. I've looked on ebay, and can't find any. Where else do you suggest I look?
P5260272.JPG Thanks!!!
  • deafrider250f
Posted August 19, 2014 - 02:36 AM
If the last owner removed the pea shooter, no biggie, it will still be well under the db limit...even the gytr performance insert is noise level is under the db limit...
  • MANIAC998
Posted August 19, 2014 - 05:22 PM
Not for Canada. 92db allowed up there.
  • Ro9
Posted August 31, 2014 - 01:57 PM
Hi, can you post a pic of Your exhaust tip? :)
  • Spiritwalker2222
Posted August 31, 2014 - 08:51 PM
The Boogie is 94 db.
http://bma1.ca/2014-boogie.php
  • MANIAC998
Posted September 01, 2014 - 02:32 AM
Thanks Spiritwalker!!!
  • deafrider250f
Posted September 01, 2014 - 05:03 AM
Look into pro moto billet endcaps...they carry spark catchers and a line of "quiet inserts" under 96bd for stock mufflers or you may have to order the " pea shooter" from the yami dealer... i also found out the 2012 wr250f and 450f share the same pea shooter according to the OEM #s...
Edited by deafrider250f, September 01, 2014 - 05:13 AM.
  • RockerYZWR
Posted September 01, 2014 - 06:16 AM
If you want a stock pea shooter and it'll fit (off an '11), I can send you mine if you want. It sits in a box and I can definitely live without it. Let me know!
