2006 yamaha yz450f. coolant in oil
5 replies to this topic
  • billcowher
Posted August 17, 2014 - 08:13 PM
Very concerned just purchased bike and found milky colored oil. Was just recently rebuilt and bored before I bought it with new radiator and lines. Just learning in and outs of this machine so any help much appreciated. ......
  • NEKOOHC
Posted August 17, 2014 - 10:59 PM
A leak down test will find the issue .
  • NEKOOHC
Posted August 17, 2014 - 11:04 PM
http://www.thumperta...t#entry10019954
Posted August 18, 2014 - 07:38 AM
A leak down test will only lead you to the cause if it's related to a combustion chamber leak, like a head gasket.  It will not reveal a leak at the water pump feed passage that runs past the base gasket and crankcase cover.  On the other hand, the head gasket is a more likely suspect.  But a head gasket can also leak from the coolant passage to the crankcase or to an oil feed passage without showing much of a combustion leak, too.  Iffy deal, but probably a head gasket.
  • billcowher
Posted August 19, 2014 - 03:28 AM
Awesome info thank you.. going to start tearing into this weekend. And I dont think this is a small leak either. Almost seems like a hose is hooked up in the wrong place from the amount of antifreeze like they are connected.
  • billcowher
Posted August 19, 2014 - 03:29 AM
If I open the plug by shifter for the oil the radiator basically drained down through the bottom end
  • 5 replies
  • Hot  30 replies
  • Hot  50 replies
  • On January 15, 2017
  • 10 replies
