Fork seals
5 replies to this topic
  • avlisj
Posted August 15, 2014 - 06:48 PM
Anybody have recommendations to a good brand of fork seals. Oem. Whatever? One that won't leak after two rides.
  • stevethe
Posted August 16, 2014 - 05:29 AM
Stock work fine but you better make sure you sand out and nicks in the tubes or the same reason that caused it to leak will happen again. Also seal savers has stopped mine from leaking for years. Protect the tubes from scratches.
  • Krannie McKranface
Posted August 16, 2014 - 05:51 AM
SKF FORK SEALS
  • GuyGraham
Posted August 16, 2014 - 06:41 AM
Its most likely not your seals, but grit/dirt trapped under them makling them leak
I had the same problem when I first got my WR, changed seals 3 times in a matter of weeks
Then I found this
Haven't put any new seals in for about 3yrs now
when they leak, I just clean them out
  • avlisj
Posted August 16, 2014 - 07:49 AM
Then I found this
Thanks
I've used that and the red one that you snap onto fork tube but never seems to work for long
After watching the video though, I've never recet the seal. So hopefully that will be the trick. Bike only has 10 hrs on it. Can't imagine the seal is already shot. Don't like running wet suit arms on my forks either
  • GuyGraham
Posted August 16, 2014 - 08:24 AM
you haven't got a ty-rap around the fork have you - this pushes dirt up into the seal and causes leaks
Keep trying with the seal-mate - its never failed to work for me
push the hooked end up as far as it will go
rotate lower fork (brake cable with need removing) whilst holding seal-mate against stanchion, around 3or 4 times and then pull it out. repeat  a few times and then try it
