throttle top screw lost
10 replies to this topic
  • NHdirtmonkey
Posted August 15, 2014 - 05:21 PM
i have no idea when my throttle stop screw went missing, it was the short one that came with the gytr computer. can anyone tell me what damage could have been done and what i need to buy to replace it, or how i can plug the hole now
  • Speedy1210
Posted August 15, 2014 - 05:34 PM
Did you not notice your bike revving to the moon
  • NHdirtmonkey
Posted August 15, 2014 - 05:38 PM
i dont ever have it wot for long enough to let it rev that high, i also was under the impression that the new shorter screw doesnt actually stop the throttle it just plugs the hole. not to mention i bought it about a month ago and it could have been missing all along because i bought it with the computer already installed and i had no idea to look to see if the screw was there or not. thought a dealer would be a bit more trustworthy than that
Edited by NHdirtmonkey, August 15, 2014 - 05:39 PM.
  • avlisj
Posted August 15, 2014 - 05:59 PM
Running with no screw only let dust and dirt where your throttle cables run around the pulley. Should probably take the black plastic cover off and clean dust out. Relive cables. Then buy another screw to stop up hole. Not sure of size
  • Krannie McKranface
Posted August 15, 2014 - 06:10 PM
If you do a search, you can find the length in which to cut the stock screw to match the yz screw
  • NHdirtmonkey
Posted August 15, 2014 - 07:37 PM
I don't have the stock screw :(
  • vlxjim
Posted August 15, 2014 - 09:33 PM
Its just there to plug the hole. There is a hard stop casted into the body. You can plug it with a screw or just a little silicone.
Posted August 15, 2014 - 09:36 PM
I though it was there to prevent the throttle wheel from turning too far.
If it does turn to far, the slide can hang wide open and get stuck.
  • avlisj
Posted August 16, 2014 - 08:01 AM
It's just like a throttle stop on a 50. Only down on the throttle body. Not throttle grip. Like said previous the throttle body is cast with a notch that catches a tab on the pulley,not allowing over rotation. Just plug the hole with something. Go to osh and but a 6m. 8m. 10m 1/4 long. One of those should fit. Bet you got the right bolt in box of left overs already. Just cut it short. Take off your silencer then the plastic black comer on throttle body ( one screw right in the middle) it will all make since
  • NHdirtmonkey
Posted August 16, 2014 - 08:54 AM
ok thank you! i will dig into it today
  • ballisticexchris
Posted August 16, 2014 - 09:13 AM
Just zip tie the damn thing and ride! :thumbsup:
