Output Shaft End Float
1 reply to this topic
  • geezerjay
Posted August 15, 2014 - 01:15 AM
Hi guys,
Been having some gear change problems on this bike a WR450 06 and noticed there was a lot of end float in the output shaft...
I've been looking at the tech drawings, but can't see a thrust washer or anything that could wear out, any thoughts on what it could be.
  • Krannie McKranface
Posted August 15, 2014 - 06:30 AM
Bent shift forks, worn / damaged shift drum, or broken detent spring/holder are the likely trouble spots
