oil leak from crank case cover?
12 replies to this topic
  • MountainRider35
Posted August 13, 2014 - 06:06 PM
Hey every one I just picked up an 05 WR450F I have put some new tires on it and a new air filter will be doing more soon just enjoying it right now, now the problem is it appears to be leaking oil from the crank case cover is this a common problem? Also it looks like ill be able to replace with out pulling the motor just would like to make sure also any advice or tips is always appreciated I will have pictures up soon.
  • crooks420
Posted August 13, 2014 - 09:20 PM
Degrease the motor to make sure where the oil is leaking from.
Do you know what if any mods were already done to the bike?
Jesse
  • MountainRider35
Posted August 14, 2014 - 08:08 AM
I have degreased the motor it was one of the first things I did when I got it I like starting clean.
As far as I know the air box mod and the tps has been unplugged looks like the ais has been removed it has a three gallon yz tank, really weird part is the PO did the grey wire mod but instead of cutting the wire or depining it he installed a toggle switch. cant see the oil leaking in the picture but should give an idea of where its at.
  • Krannie McKranface
Posted August 14, 2014 - 01:27 PM
Can't tell where you say it is leaking from
Probably an outside case that is cracked, or a cover that was installed with a pinched gasket....or even a stripped case bolt not providing enough tension.
Can't tell from your info
  • still2smokin
Posted August 14, 2014 - 02:11 PM
I cant see it either,  let it leak so we can see it or put a pencil tip where its leaking while you take a pic .
The tank is an IMS tank and it is a problem .
Do a search and you will find stories of them catching fire .
The main reason is balance fuel line above the exhaust.
I would remove it and plug it up.
I have an 05 with the same tank , however mine came with out the line on that side but I have had
other issues with that tank as well.  It sits to close to the valve cover on the left side , mine actually touched
and on long slow rides would boil gas in the tank . Installing heat reflective tape under the tank and adding a
rubber shim at the back of the tank lifts it enough where it does not touch preventing the boil.
The gas in the tank still gets hot sometimes but has not boiled again.
Posted August 14, 2014 - 06:15 PM
Yeah, you have to shim those tanks with 3/8"  or higher closed cell foam
  • MountainRider35
Posted August 14, 2014 - 06:57 PM
So I think that this could be a problem
IMG_20140814_193942764_HDR_zps2e59bb34.j
 I was able to get the bolt out and replace the gasket every thing is good now took it on a short ride like is gone the leak was coming from the bottom of the crankcase on the right side.
One good thing was the dealer gave me the gasket and the bolt for my problems and about the gas tank I knew it wasn't the stock yz tank but a aftermarket one from what I was told also could you tell me more about those problems with the tank maybe some pictures and I do have the stock tank should I just switch back to that. I also forgot it has a full exhaust
  • still2smokin
Posted August 14, 2014 - 09:01 PM
http://www.thumperta...-wr450/?hl= ims
  • torkd14
Posted August 17, 2014 - 07:33 AM
Not trying to take over this thread but does anyone know if you can get an aftermarket case cover?
I crashed my 2012 WR450 in the first turn of a race yesterday and didn't realize my shifter bent inward which rubbed on the case for the rest of the race. It now has a vertical gash with a pin hole through it from the shifter. I don't really trust the liquid metal technique...
Posted August 17, 2014 - 07:51 AM
Gonna have to be from a dealer or ebay.
The JB weld Marine works very well.
  • torkd14
Posted August 18, 2014 - 06:08 AM
here's a pic of the damage. Looking at it now it should be a pretty simple fix with some JB weld. The new cover is $180.00 online, probably $300 at the dealer.
  • crooks420
Posted August 18, 2014 - 04:36 PM
Save the money and JB Weld it.... it will last the life of the bike if done properly.
Jesse
Posted August 18, 2014 - 06:15 PM
Grind the sharp edges off of your shifter....
