YZF 450 Air Flow Through Camshaft Breather Pipe ?
8 replies to this topic
  • mla2k4mla2k4
Posted August 13, 2014 - 05:57 AM
Hi everyone,
Im going abit mad, I was at my local track on Saturday and for the first time ever I noticed that there was a considerable flow of air out of the breather pipe coming from the camshaft cover (about as hard as you could blow through the pipe if you tried only continuous)
so my question is, is this normal?? I've never noticed anything like this before.
My mind is torn between the optimistic dont worry the camshafts are spinning that must be the cause....
and terrible thoughts of cracked heads and leaking valves (seals?)
other notable points:
the air is not smokey, or particularly warm or hot
another breather is present that goes to the frame - this is also pressurised the same
Can anyone with a similar bike check this for me??
or anyone with similar experiences?
Thanks in advance for the help I dont have anyone i can ask locally
edit: The bike is a 2003 yzf 450 - No mods
Edited by mla2k4mla2k4, August 13, 2014 - 05:57 AM.
  • mla2k4mla2k4
Posted August 13, 2014 - 05:58 AM
Hi everyone,
  • Danpadula
Posted August 13, 2014 - 06:14 AM
If you can wait till 7 ill let you know!
  • bikedude987
Posted August 13, 2014 - 06:46 AM
it's called the crankcase breather.  It normalizes pressure when the piston moves up and down (changing volume inside the crankcase just like it does in the cylinder).  A lot of people route this into the airbox so it stays clean, preferably on the filtered side.
and YES, that much air movement is normal.
Edited by bikedude987, August 13, 2014 - 06:46 AM.
  • billygildark5007
Posted August 13, 2014 - 09:34 AM
It's normal you've just never noticed it before.
  • minimadness047
Posted August 13, 2014 - 04:52 PM
Ya it's normal Like bikedude987 stated it's for relieving crankcase pressure when the piston goes up/down
  • EnglertRacing
Posted August 13, 2014 - 09:11 PM
if theres alot it could be whats called BLOWBY
which is an indication you need new rings.
  • mla2k4mla2k4
Posted August 14, 2014 - 12:53 AM
Thanks for the reply's guys, after looking some more i could find one thread that said 'all is fine' as well. So now I can relax a little :)
I'm happy with that because I've had plenty of trouble with it already so paranoia is setting in.
What I don't understand with all the answers is the reasoning why though?:
I'm obviously missing something, but how is the camshaft cavity connected to the crankcase cavity? there are no breather pipes linking the two so how can piston movement/blow by be the cause of air movement up there?
  • mla2k4mla2k4
Posted August 14, 2014 - 12:54 AM
Ah what a moron....... where the camchain runs
wish I thought of that last weekend.
Thanks again.
  • On January 15, 2017
  • Hot  47 replies
  • Hot  36 replies
  • 10 replies
