Fuel leaking from carb
8 replies to this topic
  • benjar
Posted August 12, 2014 - 05:11 PM
I have a 2000 WR400 that is leaking fuel from the brass inlet piece on the left side of the carb. I tried to replace the O-rings inside but can't find any that fit.
The local Yamaha dealership's schematic doesn't show the o-rings so I don't what to order. Does anyone know where I can find o-rings to replace the worn ones on the brass inlet piece?
ImageUploadedByThumper Talk1407892256.992361.jpg ImageUploadedByThumper Talk1407892277.493766.jpg
  • Krannie McKranface
Posted August 12, 2014 - 06:08 PM
Take the inlet and the oring to a 'real' hardware store that carries all the oring sizes.
Don't use plumbing orings, as some are real rubber, which you do not want.
  • MANIAC998
Posted August 12, 2014 - 06:12 PM
While riding my '06 down in Baja, mine started leaking, so I wrapped Teflon thread tape around it, and it sealed right up.
  • benjar
Posted August 13, 2014 - 06:28 AM
Thanks for the help. I think I'm going to try the local hardware store or automotive store. If that doesn't work I may need to get creative.
  • DunmireD001
Posted August 13, 2014 - 03:37 PM
Step 1) Spit, bubble gum, bailing twine, duct tape.
Step 2) revert back to step 1.
  • adam500
Posted August 13, 2014 - 03:40 PM
Like they said, try to find a fatter ring that will not melt when gas hits it.
I would also put a dab of Yamabond on it when you install it. Can't hurt.
That stuff is great. I havn't used regular RTV for anything in years.
  • Fyrflie
Posted August 20, 2014 - 12:11 PM
My 2002 WR426 did the same thing and I was referred to this company by a local KTM dealer.
Sudco International
www.sudco.com
They have any and all parts for your carb.
The O-Rings are an oddball size and cannot be found in hardware stores.
Sealant of any kind won't work as a permanent fix because the fitting is designed to rotate.
Hope this helps.
  • Spokes
Posted October 11, 2014 - 03:12 PM
Any updates on this?  My 2007 just started this.  Any part numbers?  Thanks!
Posted October 11, 2014 - 03:14 PM
Your yamaha dealer can order them if they don't have them
Any motorcycle dealer that sells dirtbikes can order them as all dirtbikes till 2011 used the FCR carb.
