Next step
43 replies to this topic
  • Krannie McKranface
Posted March 13, 2015 - 11:07 AM
#41
Supposedly Saturday
Changes:
- Stock wheels with Tubliss
- Stock NOS OEM triple clamps
- Modified Shim stack and oil height in the SSS forks
- New bars, clutch lever, clutch cable, clutch pack (OEM)
- BRP submount, frame post for Damper (GPR riser and damper for sale....)
- '07 YZ exhaust cam (modded pin), WR intake cam (hot cams YZ spec cam set for sale...)
- fixed and polished Transmission
- Newtome 3.2 IMS tank (old one cracked to pieces)
- 12 degree advance across the board in the # 2  Dynatek map
Plus the already:
- SSS front and rear
- OS radiators
- Xtra tall seat
- Xtra tall bar risers
- IMS F3 low pegs
- Stage 3 port and polished head
- 2007 YZ carb (I thought my WR carb might have had a problem, otherwise I wouldn not have changed the carb)
- Dubach Racing full Stainless exhaust
- '12 head light shroud with HID, '12 front fender
Posted March 20, 2015 - 10:44 AM
#42
Clutch basket was heavily drilled, new T3 clutch cable, new ARC-X levers......now the clutch feels like a 125 !!
Posted May 04, 2015 - 04:21 PM
#43
99% finished!
The worlds most expensive WR450F!  What the F!?
11174425_10207009907512997_8793800994756
Edited by KRANNIE, May 04, 2015 - 04:21 PM.
Posted May 05, 2015 - 02:40 PM
#44
Results:
2007 YZ ex cam, 2008 OEM WR in cam, Ported head, YZ carb specs (+ NCVS needle / 3rd):
- Flatter powerband, no flat spots, roll on power is much more consistent, lugs great, revs not quite as great, but I dont' care. Now the powe delivery is more consistent across the rpm range.
- Thottle repsponse is back to normal WITHOUT THE STUPID CRAPPY POORLY TIMED  HOT CAMS. They are full of crap and can't disparage them enough......
- Grinding the ex decomp pin was a PITA. The 1.0mm grind was not enough. Took several attempts. Paul finally got it to 65 psi, and it starts immediately everytime.
- "Swiss-Cheese" mod to the clutch helped a GREAT deal. Better feel, more consistent engagment, lighter feel, and less throw. Motion pro cable is proabaly 20% of that.
- Stock wheels and triples: much better look, much more precise feel to the ride and steering.
-  Trans polishing made the clunky shifting feel dissapear. Feels like a Honda now.
-  Suspension is too non-compliant. I think I am oversprung for sure in the front (.56).
Well, it's still has the 'old school' chunky vibratey feel to the motor, and the whole bike feels more 'crude' after a few months on the KTM, but man are the ergos and handling GOOD on this bike.
Very easy to ride slow or fast.
