Next step
43 replies to this topic
  • Krannie McKranface
Posted August 11, 2014 - 07:03 PM
Time for a minor refresh
Nearly swamped......
½” SHRINK TUBE FOR BRAKE SWITCH WIRES
CHANGE BRAKE SWTICH
NEW DRAIN CRUSH WASHERS
CHANGE OIL
CHANGE OIL FILTER
REPLACE FRONT TIRE  (HAVE)
REPLACE BACK TIRE     (HAVE)
CLEAN OUT BAR CLUSTER SWITCH
INSPECT FLOAT CHAMBER, AND CHANGE TO RD FLOAT BOWL  (HAVE)
DROP NEEDLE ONE CLIP
CHANGE CARB HOSES (SILICONE FANCY COLOR)
RE ROUTE ALL VENT HOSES UP (BUT ONE, TO LOOP)
FILTER HOSE ENDS
NEW SWINGARM CHAIN RUB STRIP  (HAVE)
Edited by Kah Ran Nee, August 11, 2014 - 07:04 PM.
  • RockerYZWR
Posted August 11, 2014 - 09:41 PM
I think we've got the same helmet. VFX-W Dash TC2? Anyway, with that first picture - "Go ahead and just set 'er down anywhere. Yep, that's perfect."
  • KennyMc
Posted August 11, 2014 - 11:45 PM
CHANGE BRAKE SWTICH
CHANGE OIL
CHANGE OIL FILTER
FILTER HOSE ENDS
I have 2 filtered carb vent hoses going up under my seat. That was as per the instructions at least.
  • RMK800
Posted August 12, 2014 - 05:14 AM
When you do that, can you take pictures of which air vent hoses go under the seat?
Posted August 12, 2014 - 05:15 AM
I was lucky.  5 more inches of water and I would have swamped out for sure.
I was able to lean the bike over on both sides and drain out most of the puke gas, and it was rideable for the rest of the day.
  • KennyMc
Posted August 12, 2014 - 06:42 AM
Do you have the filtered vent hoses or are you gonna be getting them? I went with the 7602Racing ones.
The lower ones actually drain the fuel in a tip-over, you don't want those to be re-routed upwards. It's the ones on the upper part of the carb that get re-routed to under the seat. Can't be more specific as I don't have access to my bike at the moment.
I put in the filtered lines to avoid the "dirt creep" into the carb. The water stalling out was a side benefit.
Posted August 12, 2014 - 10:44 AM
One vent gets looped over the top of the carb and down next to the bowl
The drain goes straight down
The others go up under the tank.
All but the drain get filtered
I ordered a colored silicone hose kit
Posted August 12, 2014 - 10:47 AM
Upon further inspection, it's clear I need more 'freshening'.....
CHANGE BRAKE SWTICH
CHANGE OIL
CHANGE OIL FILTER
FILTER HOSE ENDS
NEW SWINGARM CHAIN RUB STRIP - DONE 8.12.14
NEW BOTTOM CHAIN GUIDE - TMD
NEW CHAIN - DID VT2 120LINK
NEW SPROCKETS - SUNSTAR STEEL 14/51
REPACK DUBACH MUFFLER - DONE 8.12.14
REPLACE APUMP DIAPHRAGM
  • MidlifeCrisisGuy
Posted August 12, 2014 - 11:16 AM
Was the parking job in the first picture the result of a get off or the lack of a kickstand ? Are you parked at the intersection of a switchback ?
At least you didn't need a kickstand in the second picture !
Posted August 12, 2014 - 01:21 PM
That is not an intersection
See the branch in the picture? There is a much larger, lower one before it.
I pretzled my body to avoid it, and lost my line, right into that wash-out in the trail
I was going slow enough to not do a full endo, but more of a side-o.
Posted August 15, 2014 - 09:33 PM
Tube routing correction:
Left side of carb has a 'T' section with (2) hoses
Right side of carb has a 'T' section with (2) hoses
Bowl cover has an over flow with (1) hose
Take one left and one right hose and connect them with a new  plastic or brass 'T' fitting, add a section of hose to create one hose end.  Put a filter on it and run it under the tank
Take the other left and right nose, do the same thing, but run them down to the hose holder near the swingarm. Put though holder and add a filter.
Take the bowl over flow, and route it in a loop: down, up over the height of the float bowl, and back down through the hose holder deal-y on the carb.  No filter!
Now the carb will breath (receive atmospheric pressure on the fuel in the bowl) even if the lower tubes are under water.
Why not run all 4 hoses under the tank?
Because you need as many possible atmospheric pressure points as possible, and hoses in the breeze get different pressure than those that are isolated.
You want to average the pressure out.
So you need to separate them.
Edited by Kah Ran Nee, August 15, 2014 - 09:34 PM.
Posted August 16, 2014 - 11:31 AM
photoisupsidedownforsomereason?
Edited by Kah Ran Nee, August 16, 2014 - 11:32 AM.
  • mebgardner
Posted October 27, 2014 - 08:42 AM
Nice!  I bought a new TRD chain guide based on this recommendation.
  • Kcizik
Posted October 27, 2014 - 09:48 AM
I can see from one of your pics you have the vent tub capped off above the starter gear. Isn't that where the oil drains back too from the crank case vent? I only ask because I got my bike in a pile of parts and I'm still trying to get everything back together properly.
Posted October 27, 2014 - 09:57 AM
It's not a problem
The YZ vents into the airbox or on the ground.
  • Kcizik
Posted October 27, 2014 - 01:12 PM
It's not a problem
Ok awesome. Would you be able to post up some detailed pics? I would like to see how it's done.
Posted October 27, 2014 - 03:08 PM
No pics for about a month
Motor is being fully rebuilt as we speak
All you do os temove the T, cap the starter vent, and route the hose into the airbox like stock
All hosing junctions available at Pep Boys
Edited by Kah Ran Nee, October 27, 2014 - 03:10 PM.
  • Kcizik
Posted October 27, 2014 - 06:19 PM
Ok, got it.  So, what prevents oil build up in the airbox?  Because with the vented air, there's oil mist. Correct?  Wouldn't that create a puddle of oil eventually?  Did you notice an increase in oil consumption?
Man, what I would give to have a pep boys here...
Posted October 27, 2014 - 06:33 PM
Unless you are running at 8k rpms for 50 miles, you won't notice anything substantial in the air box........unless you do a nice long wheel-stand, or go upside down.... no different from stock.
  • revelc
Posted October 27, 2014 - 07:26 PM
Have long wheelies ever caused problems with the crankcase tube?
2014 WRR-Totalled
2012 WR450F-Stolen
2012 WR450F-Third bikes the charm.
