will other magnetos will fit a WR
5 replies to this topic
  • ranmx
Posted August 09, 2014 - 06:39 AM
Hello
my magneto groove got wrecked ( where the woodruff is ).
i treid to search on ebay a magneto for the 2005 model but there are only for the later models.
and the MX dosent look even close to mine.
but the YFZ (atv) looks very similar, the catalog number are not the same.
would a YFZ magneto will fit and work on the WR?
because a new one is to expensive, also at a lathe shop its not very cheap.
  • DeepPurplishBlue
Posted August 09, 2014 - 06:36 PM
I presume you mean the rotor (flywheel) ??
If so, then yes, certain ones of the quad version will fit.   Off the top of my head I do not remember
the specifics but if you find ones close to the model year of your bike (04, 05, etc) you are probably
OK.
A popular mod with the quad guys is putting the wr450 crankshaft in the quad motor because it is
lighter and spins up faster.   the original quad rotor fits on the wr crankshaft and off they go.
I put a flywheel from a 05 quad on a 04 wr450 so it does work in reverse also.
  • ranmx
Posted August 10, 2014 - 08:47 AM
OK.
great thanks
and it has the same position for the camshafts? or i will need to make some modification with it?
and yes i ment the flywheel rotor or rotor assy, here its called a magneto.
Edited by ranmx, August 10, 2014 - 08:51 AM.
  • DeepPurplishBlue
Posted August 10, 2014 - 09:02 AM
great thanks
Here, the whole stator+rotor unit is called a magneto, or at least used to be.  The flywheel was
always called flywheel and still is.   Goes back to the days of using points for ignition.     Most people
do not use the term magneto anymore though.
Not sure what you mean about same position for the camshafts...    how is that related to the
damaged flywheel?
In any event, the quad cams are physically the same.   I think the quad uses a different lift profile
but they swap between the engines without issues.
  • ranmx
Posted August 10, 2014 - 10:13 AM
damaged flywheel?
only the groove is damagde.
you have a dot on the rotor, its the same position as on the WRs one?
when you sinc the cam and the rotor.
thanks!
  • DeepPurplishBlue
Posted August 10, 2014 - 10:48 AM
thanks!
Yes the timing marks are the same
