Oil change bolt size help
1 reply to this topic
  • gerg73
Posted August 07, 2014 - 02:06 AM
Quick question and cant believe I'm asking this ;)
Just dumped and re-filled the oil on 08 WR450.
Sump bolt back in "check".
Now I have 2 bolts left over:
The oil level check bolt that goes in the crank case and the  other one that goes in the cylinder.
They are both different lengths and I cant remember which one goes where.  The manual doesnt really (from what I can read) say where the long/short bolt goes.
Appreciate any help :)
Thanks.
  • bobpara
Posted August 07, 2014 - 03:38 AM
The long one will bottom out and the bolt head will not seat properly if you put the long one in the shallow hole.
You have a 50 /50 shot
