Hot start plunger question
4 replies to this topic
  • 300lbsgorilla
Posted August 03, 2014 - 05:47 PM
Had my bike (2004 wr450f) out today in tight woods.  It was of course getting a bit hotter from working harder and moving slower.  It was hard to start hot.  The hot start was disconnected by one of the previous owners.  a plug was put in its place with a spring and a plunger in the carb.  I am getting the zip-ty nut on as well
Turns out the valves clearances were a bit tight too so getting that sorted as well.  That may have something to do with it.
My question is I have read in other threads about lubing the plunger and the seal to make sure it is nice and air tight, but what do I lube it with?  I am just concerned because I don't want it to disolve with the gas vapor (if any) or melt and drip out and plug something.
Edited by 300lbsgorilla, August 03, 2014 - 05:48 PM.
  • stevethe
Posted August 03, 2014 - 06:28 PM
The o-ring should be made to hold up to gas. Some people use assembly lube others just use a dab of regular grease.
  • Krannie McKranface
Posted August 04, 2014 - 04:47 AM
Water-proof Grease
You need to lube the cable fairly regularly, but when you do, the lube goes down into the hot start cavity, diluting the grease.....so you need to use the high-temp water proof grease that does not dilute with solvents
http://www.motorcycl...perature Grease
  • fixitandy
Posted August 07, 2014 - 05:09 AM
Hi mate, I had hot start plunger woes once & tried all sorts of different types of grease, I now use anti-seize, no drama's since, just throwing it out there, ROOSTA out!
Posted August 07, 2014 - 05:19 AM
Yes, I use Honda Anti-sieze on the plunger, mixed with waterproof grease
