2010 yz450f only running on Choke...?
4 replies to this topic
  • moto450mx
Posted July 31, 2014 - 12:04 PM
Well I'm having some issues. I got out of mx to focus on trials and let my bike sit for about a year without running or riding it. I drained the old gas and tried to start her up but she's not doing to good. I can only get it to run on with the choke on and when I flip it off the bike dies. I'm about to go check to see if there's a good spark but this is my first issue with a fuel injected bike. Not sure where to go after this if its not a dirty plug.
 By the way shes a 2010 yz450f.
Stock motor with yoshi exhaust.
Any help is greatly appreciated!
  • moto450mx
Posted July 31, 2014 - 12:28 PM
Well problem solved. Looks like it just had a bit of old gas that needed to be run through. Went out there started her up and turned choke off and she sputtered a bit then picked up and sounded good as new.
  • moto450mx
Posted August 02, 2014 - 05:39 AM
Ok apparently the problem is not solved. It now runs with the choke off but doesn't want to idle! I have adjusted the choke knob/ idle adjustment all the way and it doesn't change a thing.
Any ideas?
  • ratom98
Posted August 03, 2014 - 02:48 AM
you mean the hot start? don't think the fi models have a choke. new gas, clean air filter and a new spark plug are the cheap things to check
  • AndrewAndrew213
Posted August 03, 2014 - 07:39 AM
I would run fuel injector cleaner, run it pretty rich to like 3 times the recommended amount and ride it pretty hard, with a year of sitting around the old gas probably left some build up in the tank/injectors
Need help by Goforaride
  • Hot  68 replies
  • 0 replies
  • 5 replies
  • Hot  33 replies
