Fork Oil. From 5 weight to 2.5? XR650
9 replies to this topic
  • slowxr
Posted January 26, 2004 - 11:16 AM
How does the lower fork oil weight affect handling? I noticed this recommendation for XR650's and was curious what could be expected with the lower weight on stock forks?
  • TimBrp
Posted January 26, 2004 - 11:26 AM
Not really quite sure. I think it will make the pig a bit plusher in the trails but a lil more unstable at higher speeds. I called xr's only for some oil and said I need to stiffen it up and they sent me some 10w oil.
  • BrianVT
Posted January 26, 2004 - 11:40 AM
I just loaded mine up with 2 1/2. I won't be able to give an opinion for a couple weeks though. I got it all stripped down.
The bottle said lighter oil is more sensitive to changes of settings (clickers).
  • TimBrp
Posted January 26, 2004 - 12:56 PM
Brian, didn't you just do yours a few months ago?? :)
  • BrianVT
Posted January 26, 2004 - 01:13 PM
Naw, I was just setting the sag and clickers at that time. I am running the settings you suggested, b.t.w. Thanks for that.(Edit, I just realized the settings were from John on 4Strokes.com) What are your settings Tim ?
I'm at: Forks comp. 15 out, reb. 9 out
Shock comp. 13 out, reb.16 out
I haven't experimented at all.
I don't fly my pig too high so I thought I'd try the 2 1/2 just to see how it feels in stuff like the Rocky Woods Enduro.
Cheers,
  • slowxr
Posted January 29, 2004 - 01:59 PM
I just serviced my XR forks after 300 miles of riding. The oil that came out of the forks was thick and sticky. I replaced it with 2.5 weight.
After riding the bike, I didn't notice much difference over the stock oil. I was able to notice a slight difference when I adjusted the compression clickers which I couldn't with the stock oil. I guess that's an improvement.
  • BWB63
Posted January 29, 2004 - 05:28 PM
The biggest difference is at high speed through the the big whoops and drop offs, give a more even flow (plush) allowing for a better responce from you as the hits come.
  • TimBrp
Posted January 30, 2004 - 05:13 AM
Cheers,
Stock right now Brian...Yeah, feel for me :)..I'm getting mine done by the suspension dr on NEDB in two weeks...Can't wait.
  • BrianVT
Posted January 30, 2004 - 07:16 AM
Aww mannn...now I'm gonna hear all your praise about your susp. and I'm gonna have to scrape up the coin to get mine done. I'm sure he'll set you up right.
  • TimBrp
Posted January 30, 2004 - 01:21 PM
I hope he's as good as they say he is. Cheap coin man like 400-500 bucks. Beats anywhere else and he's right down the street, from me. :)
  • 2 replies
Fell Off Trailer by usafxr
  • Hot  43 replies
  • 8 replies
  • Hot  171 replies
