Footpeg Bolts
4 replies to this topic
  • JackAttack
Posted January 26, 2004 - 11:08 AM
I jumped off a hill and landed in a wash....snapped the right footpeg off. Not a fun experience at 40MPH. I usually check on the tightness of the bolts a couple times a month, did'nt catch it this time.
The bolts snapped clean. I drilled and used an easy-out to remove the broken studs. I don't really want to spend the $$$ on an upgraded footpeg mount. Thought I would just purchase some higher grade bolts and use gobs of thread-lock. Maybe throw in a lock-washer. What are the torq specs for the bracket bolts? I really don't want to strip out the threads in the frame.
I did a search(TT,XR650R.net) and this looks like the typical solution.
Might need to loose a few lbs. myself too.
Ride On :)
  • needsprayer
Posted January 26, 2004 - 04:45 PM
Right footpeg, both front mounting bolt (socket bolt) and rear mounting bolt (flange bolt): Torque: 54 Nm, 40 lbf-ft.
Hey Jack,
Did you do this on your Baja ride? Did you take any pictures?
  • JackAttack
Posted January 26, 2004 - 09:32 PM
No, things went pretty smooth in Mexico. I was not in Baja, but Puerto Penasco, right across the Sea of Cortez from San Felipe. I will send you some pics when I get them back.
Funny thing is, I towed a guy for almost 40 miles when his KTM520 seized in the middle of nowhere :D. Tied him off to my left footpeg. Finally get home and ride and the right peg snaps off. :) What ever happened to Karma?
  • needsprayer
Posted January 27, 2004 - 06:16 AM
Looks like you have some major bragging rights now. Poor little KTM (Kingsize Towrope Mandatory) needed a BRP to drag it home. :) :D
  • Baja Rudy
Posted February 02, 2004 - 07:17 AM
the bolts usually break due to stress corrosion pitting. you need to replace the bolts with NEW ones every 6-8 months(use factory ones since they are coated with that black zinc plating). the aluminum frame and the steel bolts form electrolisis and therefore the corrosion. Do not re-use the old ones; put them in the trash!!! If you don't want to spend $130 for the upgrade foot peg then this is the only safe way that I know of. the great thing about the upgrade foot peg is that it distributes the load all along the forward bolt and not just close to the frame. :)
