CHOKE PROBLEM
7 replies to this topic
  • highmark00700
Posted July 30, 2014 - 02:13 PM
I have a 05 wr 450 and after you pull the choke out, it goes right back in as soon as you let go of it. Does anyone know of a fix for this? Its kinda awkward to hold the choke out and kickstart it when its cold. I did a search for a fix but the only thing I could find is to replace the choke assembely. Its only $30 but if its a easy fix like replacing an o-ring or something then I would rather try to fix it. Thanks in advance!
  • underground-mpyre
Posted July 30, 2014 - 02:27 PM
Mine does the same thing. Just hooked a piece of safety wire to pull it out enough to start it.
My buddy had the same problem and just replaced is entire choke knob assembly for $32 and viola. Obviously I need to do the same thing as you.
  • Krannie McKranface
Posted July 30, 2014 - 03:37 PM
Yeah, it's an all day project:
Unscrew the choke nut
Remove plunger
Clean
Replace o rings
Lube
Re-install
Safety wire hook huh?
Remind me not to ride in Indiana.
  • highmark00700
Posted July 30, 2014 - 05:16 PM
Remove plunger
Clean
Replace o rings
Lube
Re-install
Thanks for the input. Do you have a part number for the o-ring? I couldn't see any in the parts diagram...
Posted July 30, 2014 - 06:54 PM
It's not listed
You'll have to go to the plumbing supply / hardware
  • toad0077
Posted July 30, 2014 - 07:46 PM
I like the knowledge and experienced people comments. I can do without the caustic innuendo remarks though. cant you just politely reply if you feel the need to say anything Kah? Like I said I like the info you share but you come off as a smart ass dick in most of your posts.sorry. had to say it.
Posted July 30, 2014 - 07:48 PM
I like your posts, but I can do without the name calling and whining about the posts not being done the way you think that should be done.
Like I said, I like your posts, but you come off as complaining whiner in most of your posts. Sorry, I had to say it.
The gas goes inside the big thing in front of the seat, before you ask.
  • wadzi90
Posted July 30, 2014 - 10:12 PM
Dude you whine all the time. Especially about how koolaid makes you sick. You think your opinion is fact.
