  • Instagram
Related Reviews
Yamaha YZ450F 2007
Last review by 24moto
Yamaha YZ450F 2014
Last review by Gode
Last review by Tommyk_55
Yamaha YZ450F 2006
Last review by Yzrider1023
Yamaha YZ450F 2010
Last review by flightrider
Related Garage
Yamaha YZ450F (2017)
Owner: Tommyk_55
Added on January 15, 2017
Race motor, what can I expect?
22 replies to this topic
  • WILLIAMS37
Posted July 28, 2014 - 06:04 PM
Well, did about half the research I should have but cracked the wallet open anyways. I have a crosworth 13.75:1 piston and gytr cams on their way for my 08 yz450f. Few questions some of you might be able to help me with. Any issues using an oem head gasket? Or oem valve springs? What will these parts do to my jetting? And what octane fuel can I get away with at sea level? Any help at all would be great as I'm not finding much with this compression ratio and cam specs.
  • carlloktm
Posted July 29, 2014 - 12:10 PM
I'd also like to know about that
  • swaldrop
Posted July 29, 2014 - 01:06 PM
Problems and headaches that otherwise would never have been... That is what you should expect :)
All cynicism aside, the bike will no doubt perform better. I just never understand why, especially on a 450, anyone would sacrifice a proven motor like this for a little bit of extra power.
  • carlloktm
Posted July 29, 2014 - 01:33 PM
Thanks for ur input
So is it common to have problems with high compression pistons then ?
  • swaldrop
Posted July 29, 2014 - 01:46 PM
It has been my experience, both personally and through proxy, that any time you start changing things with the engine beyond the OEM spec you will create problems for yourself. My input is nothing more than me speculating as I can't say for sure if these specific mods will be an issue or not. So, take it for what it's worth, which isn't a whole lot in this case.
That said, it's a freakin 450! It's already a beast.
  • carlloktm
Posted July 29, 2014 - 01:51 PM
Ok thanks a lot
Think I'm just going to keep standard for a while
Mines 426 though not 450
  • WILLIAMS37
Posted July 29, 2014 - 04:27 PM
Appreciate the heads up, but I have a stock 450 to ride whenever this will be for racing only, so it's not like I'm expecting 400 hours out of it. But some insight on tuning it in would be mighty helpful. Most of these parts are getting pretty close on the shipping tracker! Btw this build is a motor learning experience, I know it wont sound practical to most.
Posted July 30, 2014 - 07:10 AM
If the listing for the GYT-R cams don't specify that certain springs must be used, fresh OEM springs are good.  The OEM head gasket, correctly installed, is also plenty well up to the job.  High compression will generally tend to richen the very low end, and not particularly affect the high end.  Cams?  Just have to run it and see.
Pump gas works in most cases, but 13.75 is a little high, and together with sea level riding, you might have to go up a point or two.  Pump gas is AKI 91/92, which would give it an approximate Motor Octane of about 87/88, or a Research octane of 95/96.  If you go with race gas, look for one blended for 4-stroke bikes that has a Motor number in the 90-95 range. (Research Octane, ~100)
  • WILLIAMS37
Posted July 30, 2014 - 05:01 PM
Appreciate your valuable input Gray, doesn't seem as daunting or impractical as I first assumed. Shipping date changed from friday to august 5th to torture me no doubt.  I live in an area where I have access to vp and sunoco race fuel, sounds like ill be doing some reading up on research octane, but happy I may be able to get by with a mix of 93 pump and u4.4.
This whole project came about because I assumed and set money aside to replace my warped head.  After tearing it down though,  I found my head to be still perfectly flat, but the cylinder had wear marks on opposite sides of the wall where it had worn completely through the nikasil.  I didn't install the piston but I can only assume that attention wasn't given to the correct way the rings go on.  Learning as I go,  but I know I care about my bike more than someone who is on the clock and wanting to go home.  Should hopefully make some power without being the deepest sounding 2 stroke on the track now  :banghead:
Posted July 31, 2014 - 05:44 AM
25 years ago, any engine that had worn that far into a plated cylinder would have peeled off a chunk of it and blown parts all over a 30 foot radius.  The improvements made in last several years are stunning, taken in context.
I doubt it had anything to do with ring orientation.  More likely just simple wear; too much time on the thing.
  • tubby260
Posted January 14, 2017 - 02:49 AM
All dirt bikes call for 91 octane at the pump, nothin less. And if your going to run 110 octane or race fuel. It's best to mix a 5 gallon can with half 91 octane and the other half 110 octane. This will allow the higher octane fuel
To still burn good and clean but it won't be straight 110 that's sitting there burning up your motor. That's what I do and I race desert all the time. I learned my lesson when I ran straight race fuel and held my bike wide open on a lake bed during a race. Ya kaboom went the too end. Since then I mix half and half. Never had another motor blow on me thankfully
  • tubby260
Posted January 14, 2017 - 02:52 AM
  • tubby260
Posted January 14, 2017 - 02:54 AM
Edited by tubby260, January 14, 2017 - 02:58 AM.
  • shredmasterz
Posted January 17, 2017 - 05:39 PM
Octane rating is related to a fuels resistance to ignition. The higher the octane number the more difficult the fuel is to ignite.  Having a significantly higher octane rating than needed for the air fuel ratio, engine compression and other related engine operating parameters will actually reduce an engine performance when compared to a lower octane that is appropriate for those parameters.  I think your engine blew for reasons other than your fuel octane.   I do agree that running a 50/50 mix of (91 - 93) pump gas and high octane race fuel will be good for 13.5:1 compression with the correct jetting.
  • stevethe
Posted January 17, 2017 - 05:52 PM
You guys replying to a two year old thread? The original poster has stopped riding and taken up non competitive badminton.
  • shredmasterz
Posted January 17, 2017 - 07:03 PM
I did not see that.  That is really funny!!!
Posted Yesterday, 07:50 AM
Half true: Octane number is the fuel's resistance to ignition by any source other than open flame or spark
Again, half true only.  See above.
Not true. Octane has no direct effect on ANY attribute of a fuel other than its resistance to detonation.
The only way a fuel's octane could be connected to an engine failure is if it was low enough to allow significant detonation
Read:
www.thumpertalk.com/wiki/_/octane-ratings-higher-better-performance-right-r605?pg=1
  • shredmasterz
Posted Yesterday, 12:05 PM
After more research, my comment on reduction in power with excessive octane was incorrect.  There are many variables and differences in fuels, other than octane that can impact the output power of an engine.
gray- my other points were correct. We are talking about an internal combustion engine not an open flame ignition of fuel.
Posted Yesterday, 12:56 PM
No one is talking about anything other than internal combustion engines.  Combustion of the fuel is supposed to be initiated by direct exposure to the spark at the plug ONLY.  Following that, the open flame from the small cluster of gasoline droplets ignited by the plug is what is supposed to ignite the rest of it, nothing else.
High octane fuels are NO MORE DIFFICULT TO IGNITE by exposure to flame or spark than low octane fuels are, so those of your statements marked as half true were exactly that.
Go back and read the article again.
  • shredmasterz
Posted Yesterday, 03:44 PM
​OK I stand corrected (thrice).  Octane is the resistance to detonation, not ignition.  Thank you for the clarification.
  • Hot  36 replies
  • On January 15, 2017
  • 9 replies
