Wr450 supermoto wheel/ brake help
3 replies to this topic
  • Mbiker_101
Posted July 28, 2014 - 05:08 PM
I have a plated 08 wr450 that I'm setting up with 17" wheels motomaster 320mm rotor and calipers. When I mount on the bike it seems the calipers are not centered and are rubbing the disc. The wheels and brakes I've had for years from my yz426. How do I get them to fit my wr450???.
Seems like they are about 3mm too far in? I have the stock speedo with the gears out to space the wheels, is this the problem? What is the width of the correct wheel spacer?
  • stevethe
Posted July 28, 2014 - 08:43 PM
Hum don't know anything about the 426 to 450 wheel difference. But maybe you can switch spacers from one wheel to the other. The other option is to have custom spacers made.
My brake came with very thin shims to center the caliper.
  • Mbiker_101
Posted July 28, 2014 - 08:53 PM
Thanks Steve, Wheels are the same on the 426, do you have the moto master calipers? How much did you shim?
  • stevethe
Posted July 29, 2014 - 05:03 AM
No I don't have moto master. I've had a few brakes on her one was with a moto master disc and relocater bracket.
I just bought a Beringer brake set up new-used and noticed it came with two small shims that spaced it perfectly on the disc.
I was thinking of yours however 3mm is quite a ways. I think mine might be 1-1.5mm. I will try to look later.
