Hard to find neutral, '08 450
2 replies to this topic
  • ipsullivan
Posted July 19, 2014 - 04:25 PM
I am having a hard time finding neutral on my '08 450, when it is running. With the engine off it is no problem. No problems catching gears while riding.
I did a search and found a few threads with similar problems but didn't see a whole lot for answers.
Any thoughts?
Thanks,
Ian
Posted July 20, 2014 - 07:11 AM
The clutch isn't releasing completely enough when you disengage it.  It's called clutch drag.  It could be nothing more than you have too much free travel in the clutch cable, but most often, it's the plates that aren't flat enough any more causing that.  I recommend a new set of OEM plates.
Also look for a badly notched clutch basket or boss along the areas where the plates contact them, and for springs that are uneven lengths.
  • ipsullivan
Posted July 31, 2014 - 03:08 PM
Ok I'll look into it when I check the valves next week.
Is this something that could cause more damage of it isn't fixed? Or just wear and tear on the clutch?
  • 9 replies
  • 10 replies
  • Hot  36 replies
