'12+ WR450 FI Setting .vs CO Gas Sniffer Readings: Data Request
6 replies to this topic
  • mebgardner
Posted July 18, 2014 - 11:34 AM
If you have access to '12+ WR450 CO FI Setting (obtained by using the FI "diagnostic" tool) .vs CO Gas "Sniffer" readings data, please post it up.
I'm looking for this type of data:
(These are *BOGUS* Data here, just being an example)
FI Setting    CO Reading
3                 3%
5                 5%
.etc...
You should probably include some info about any changes (from "OEM" standard) about the motor, exhaust, and / or intake systems that are on the cycle being tested.
Sadly, I have none to offer. I do not have access to a gas sniffer.
I am able to offer the use of a diagnostic tool to someone who *does* have access to a gas sniffer, no charge, if they were willing to post up their findings here. Say, in increments of 1, from -5 to +15 (to +20?) on the FI diagnostic tool setting, and give the result in CO%.
  • mebgardner
Posted July 21, 2014 - 06:31 AM
From vlxjim (quoted from another thread):
20 ... was around 5.3 % or so. At 15 we were 3.7 with a 3 in the lower left bottom of the map.
  • 5270ADVRIDER
Posted July 21, 2014 - 04:15 PM
Our dealership has the diagnostic tool and an EGA. As soon as I install my new pipe I'll post some data from my 2013 WR450F.
  • 5270ADVRIDER
Posted July 24, 2014 - 03:37 PM
2013 - GYTR ECU, Snorkel removed, cean air filter, fresh fuel, fresh oil, Dr D slip-on (new last night). Bike was at operating temperature, ambient temp 75.
CO setting = 0    EGA reading was 2.47
Moved FI setting to 7 and EGA now reads 4.22
I'm going to run with this for a while and see what happens. I've never had hard start issues hot or cold until I switched my pipe (I had a cold start issue). Didn't need a pipe and really liked the stocker with the GYTR insert, but who really NEEDS half the stuff we bolt on or bikes? Lol     I'm a sucker for a good deal!
  • vlxjim
Posted July 25, 2014 - 07:43 AM
Thats different. I would think that the dealer use the Yamaha FI tool. I do remember that some of the Yamaha FI tools worked differently. On a new ECU some would showed minus numbers to start with. So we should state if the FI tool was the Yamaha part number or the China one. I use the china one.
  • mebgardner
Posted July 25, 2014 - 07:59 AM
Being an electrical engineer, and a computer scientist, and work to program sophisticated embedded systems processors every day, for decades, I feel qualified to opine on this difference.
I believe each of these diagnostic tools (yam or china) are merely communications devices linked to a CAN bus and operate as command / status devices.
If I command either tool to "bump an index in an embedded systems lookup table, by one index", the result in the embedded system will be the same using either tool.
I think you get the same result whichever tool is used.
  • 5270ADVRIDER
Posted July 25, 2014 - 06:42 PM
That's way over my head, but it sure makes sense. Lol.
I used the Yamaha tool that was autoshipped from the factory along with the switched harness that was made for the plug on the WR AND a very high-end EGA. Of course it was the easy button for me since it's all at the dealership that I work for.
Btw, I paid $40 for the use of the equipment, my technicians time, and misc. supplies.
