Sand in motor (12 WR450)
43 replies to this topic
  • twheat
Posted July 18, 2014 - 01:01 AM
Hi guys,
Just recently got back from a 5 day long trip for florence oregon. Bike has be parked in my garage for a month and only has 27 hours. I planned on riding tomorrow but wanted to get my oil changed. I started the process and popped the oil filter only to find it filled with sand. I know this is not good and I am surprised the bike continued to run down there but who knows how long the sand was in there. So I know I need to pull this thing apart. I am not sure how sand got in there. I had a brand new twin air filter on with a prefilter cover over it. My only guess is because the airbox had sand in it, the sand may have got drawn in throught the crank case breather. Pulled the filter and there were small particles behind it, but nothing huge, and I would think the throttle body would get gummed up first. Anyways, what would you guys do if this was your bike? My plan is to pull the motor out of the bike. Take the valve cover off and inspect the head. I plan on taking the head to a friend who runs a machine shop that does head work. I will have him disassemble it and put it through the parts washer. Obviously checking the piston and cylinder for damage is the next step. I guess my question is if everything looks good should I button it back up and ride it? My other thought is to split the cases and also have the lower halves washed out. What are your guys' thoughts? Here is a picture of the filter cover with sand on the walls with light shined on it. Thanks.
Edited by twheat, July 18, 2014 - 01:02 AM.
  • Navaho6
Posted July 18, 2014 - 02:06 AM
Heard someone mention dirt coming in from around the seal between intake boot and air box. Mine never did.
  • bikedude987
Posted July 18, 2014 - 08:02 AM
FULL tear down of that engine.  Replace anything questionable/scored.  maybe you got lucky and the sand went through the filter first, but you're probably looking at new oil pump at the minimum.
  • twheat
Posted July 18, 2014 - 08:50 AM
Ok. There is a lot of sand in the pleats of the oil filter but there was also a lot outside of it. I am concerned that if I rebuild it, how do I know all the sand is out of the oil passages?
  • GuyGraham
Posted July 18, 2014 - 09:49 AM
Dble post
Edited by GuyGraham, July 18, 2014 - 09:51 AM.
  • GuyGraham
Posted July 18, 2014 - 09:51 AM
This would just get sucked through engine, and wouldn't get into the oil
At worst it would score the bore and trash the valves
Because the filter is the first stage of the lubrication system
The oil pump takes oil from the oil tank, and pumps it through the filter, then onto the rest of the engine
This way, any crap in the oil doesn't get pumped round the engine, and cause wear/block oil passages
You should find out where the sand is getting into the oil as this is most strange
If it were mine, I'd do some oil & filter changes (like 3 or 4 in a very short space of time) and see how it goes
The damage (if there is any) is done  - you may get lucky and it maybe fine
When I bought mine with 232 miles on it (08 model), the Previous owner had had the carb off to change the jetting, throttle stop etc
Trouble is, he never put the airboot back on the carb bell mouth correctly and so it was sucking sand in through the carb
Carb was full of sand, which meant it had been sucking it through the engine
I thought the bore would be trashed and the valves knackered, but to my surprise it did 400 hours before it start burning oil. The valves haven't moved yet so are fine
There were little pock arks on the top of the piston where the sand had been trapped in the squish band but it was in surprisingly good condition given the above, plus 400 hours
Edited by GuyGraham, July 18, 2014 - 09:59 AM.
  • Navaho6
Posted July 18, 2014 - 01:05 PM
Sabotage ?  How else could it get in if not through the oil fill or dipstick holes?
Heard of guys flushing with diesel several times until it comes out clean.
Edited by Navaho6, July 18, 2014 - 01:07 PM.
  • Krannie McKranface
Posted July 18, 2014 - 02:36 PM
If there is no sand in the intake boot, you were sabotaged.
  • twheat
Posted July 20, 2014 - 09:06 PM
OK I found out where the sand entered. I pulled the vent tube off the starter one way on the left side of the motor to find sand in it. So I popped the cover and pulled the one way out and theres sand on the back side of that. The motor is out of the bike and the stator cover is removed as is the main cover around the clutch. The good news is there is no sand in the bottom of the cases. If I lean the motor on one side I can see up the cylinder and there is no wear on the cylinder walls, just cross hatching. The head also looks good. No sand. The cams look good with no signs of wear. At this point I am going to pull the head and send it to my buddy with the machine shop to give it a good wash in the parts washer. I also am planning on splitting the cases and also putting those through the parts washer just a precautionary measure. Once thats done I plan on installing a new oil pump, piston, head bolts, and replacing all the gaskets. Anything else you guys can think of?
  • GuyGraham
Posted July 21, 2014 - 12:48 AM
That pipe links to the cylinder head, and the airbox (just below the air filter - the dirty side of the filter)
It is the breather system for the crankcase
As the piston rises and falls, air is vented and sucked through this pipe work
Has sand somehow entered through the opening in that pipe at the airbox, and got into the oil
Many on here, including myself, reroute this pipe to the clean side of the air filter, by utilizing the AIS air feed, once the AIS system is removed
I didn't like the fact there was an unfiltered opening into my engine via the cylinder head & starter motor clutch housing, hence why I re-routed it
MY DRZ400 vents to the clean side of the air filter, so I saw no reason why the WR shouldn't as well
  • twheat
Posted July 21, 2014 - 08:33 AM
It must have. I do know there was some sand in my airbox when I checked it once. I removed it and carried on. I didn't see any sand in the tube that goes to the valve cover. On my 2008 YFZ 450 that I had I deleted the airbox and put a small 1" K&N filter on the end of the same breather. I'm thinking this would be the best move. Can I see some pics of the set up you have? The WR doesn't vent to the clean side. The nipple is below the airfilter. Pretty poor design IMO. Thanks for your help.
  • GuyGraham
Posted July 21, 2014 - 10:11 AM
Remove your AIS system, and re-route the pipe that fits to the airbox at the base of the airbox, to the adapter on the top of the intake boot (on the right hand side by where the seat meets the tank), that the AIS used to use to suck air in through
I will try to take some pics in due course
  • MidlifeCrisisGuy
Posted July 21, 2014 - 10:33 AM
I'd skip splitting the cases and opt for a really good flush while rotating the engine with the starter.
  • vlxjim
Posted July 21, 2014 - 10:38 AM
There is no AIS on the newer 12-15 FI WR's.
  • cubera
Posted July 22, 2014 - 05:36 PM
After the "Mud National" District 38 race a few years ago on my 450R I had to completely go through the entire bike. Cases had to be split and all bearing surfaces cleaned and inspected. It took me 6 months to get it done. Roached the machine so it was a miserable, rotten, expensive experience I will cherish forever.
http://www.thumperta...al#entry8118361
Edited by cubera, July 22, 2014 - 05:48 PM.
  • mebgardner
Posted July 23, 2014 - 10:29 AM
Are you indicating the '12+ models have the same poor venting design?
[Edit]
Oh, Duh.  Have a look at the title thread. My Bad...
Edited by mebgardner, July 23, 2014 - 10:30 AM.
  • GuyGraham
Posted July 23, 2014 - 10:34 AM
Wasn't aware of this
Have just looked at a 2012 parts diagram, and the pipe joint on the airbox boot isn't there
You may have to resort to fitting a mini K&N onto that pipe or something similar
Edited by GuyGraham, July 23, 2014 - 10:51 AM.
  • mebgardner
Posted July 23, 2014 - 10:49 AM
Have just looked at a 2102 parts diagram, and the pipe joint on the airbox boot isn't there
You may have to resort to fitting a mini K&N onto that pipe or soemthing similar
Would someone please recommend a k&n part number?
  • mebgardner
Posted July 25, 2014 - 08:44 AM
Do you have the part number for this 1" filter?
What's the effect of just plugging it (sealing it) at the airbox intake fitting?
  • mebgardner
Posted July 25, 2014 - 09:26 AM
I'm rolling with this choice:
K&N 62-1010.  2 in. Dia. x 1.5 in. long, 13 mm / 0.5 in. intake vent tube.  Rubber Top.
There were 5 choices in the 0.5 in vent tube. I did not think I could make the 3" long models fit, so that left 3 choices in the 2" dia. x 1.5 in. long models.
I think I can make this one fit, somewhere.
