Brake light issue troubleshooting
7 replies to this topic
  • Wounded Lobster
Posted July 16, 2014 - 01:22 AM
Hellooo! Just got my new regulator so trying to get all my lights up and working.
I have running indicators, headlight, tail light even but my brake light will not light up!?
The globe is fine. I first tested at the plug under the seat and I do not get current on the brake light pin by pulling either brake lever.
I then tried bypassing the front switch altogether by running a wire across the terminal it plugs into behind the headlight but still no dice!? Surely that should have lit it up?
Any ideas? A ripped/cut wire along the way seems unlikely but its about all I can think of.
Seeing as neither lever works could the problem be located where they share the same wires?
Any and all help much appreciated, thanks!
  • Thommo_400f
Posted July 16, 2014 - 04:36 PM
What bike?
Check the actual switches. Put a multimeter across both wires to brake pressure switch and push brake lever to check continuity. Do same for front brake switch.
  • Wounded Lobster
Posted July 16, 2014 - 05:46 PM
Thanks for the reply!
Sorry, 04 WR450, they come road legal from factory here in aus I think it's different elsewhere?
I figured if the switch was the problem bypassing it at its plug would have fixed it? I will check anyway.
Gonna be out there all day with a multimeter.
  • Wounded Lobster
Posted July 16, 2014 - 07:41 PM
No continuity with lever pulled. Bypassing the switch by running a wire between the plug terminals does not create current. There is about half a volt between the two plug terminals. This means it must be a bad connection somewhere between the battery and that plug, right?
Thanks again.
  • Thommo_400f
Posted July 16, 2014 - 08:03 PM
The brake light circuit is a pretty simple one. Just gota get it sorted in your head so you can test it correctly.
Diagram shows a common relay, but yours might just be a common joint. "Basically" same for all bikes.
Work you way through, you'll get it eventually
  • Wounded Lobster
Posted July 16, 2014 - 08:15 PM
Thanks for the diagram. Haha yep I thought I might be testing wrong.
I'm thinking about just rewiring the front plug to the battery + on one side and brake light + on the other. That will 100% fix any problems unless it is a grounding issue.
  • Wounded Lobster
Posted July 16, 2014 - 08:56 PM
Fixed! Pulled some un-factory-looking elec tape off and found that some turkey had cut the brake light+ wire at the rear plug!? :confused:   Reconnected and its all working fine now on both levers. Thanks for the help, that diagram is actually different to what I had assumed it would be so im glad you posted it!
EDIT: and please excuse my shameless double posting habits
Edited by Wounded Lobster, July 16, 2014 - 08:56 PM.
  • Thommo_400f
Posted July 16, 2014 - 08:58 PM
:thumbsup:
