Busted case
5 replies to this topic
  • RLV199
Posted July 15, 2014 - 04:05 PM
So my chain guard welds busted and derailed my chain which in return sent the chain careening into my case and cracking it all the way around where the clutch arm goes in..
I guess I am mainly just venting but if anyone knows where I can get a cheap case.. that would be great
As well as any info as to what I will need to do this wonderful bit of work. What should I look for that might have been damaged?
  • hillclimb426
Posted July 15, 2014 - 06:41 PM
I had a chain break and bust the same spot on my 08 mechanic had a friend that owned welding shop. That guy made a mold off another 08 case and fixed my case from that saved a bunch of $ . Clutch works just as good as new. Go talk to local welder/metal worker.
  • sploon
Posted July 16, 2014 - 12:28 AM
agreed i have seen this repaired before. a new case is about 4 - 5x more expensive than a repair but if a repair is done correctly and the cases pre heated before alloy tig welding. The repair will be permanent
  • swaldrop
Posted July 16, 2014 - 06:15 AM
What led you to the conclusion that the chain guard welds broke, causing the derailment? Under normal conditions, the chain guard is under zero load, with the only force applied to it being an improperly adjusted or broken chain. Just curious as to how this would be possible.
Edit: Are you referring to the lower chain guide? That I could see causing a problem.
Edited by swaldrop, July 16, 2014 - 06:21 AM.
Posted July 16, 2014 - 08:54 AM
If by "chain guard" he means the lower guide, those welds do occasionally crack.  If it broke free, the chain would almost certainly derail.
  • RLV199
Posted July 16, 2014 - 01:00 PM
Sorry yeah I totally meant guide
  • On January 15, 2017
  • Hot  50 replies
  • Hot  113 replies
  • 10 replies
