2005 yz450f oil coming out of my blow by tube
2 replies to this topic
  • djryder510
Posted July 14, 2014 - 07:24 AM
Do i need to do a top  end rebuild? Are the o rings going bad? To much oil? Sorry i'm  a bit ignorant on this subject
  • Krannie McKranface
Posted July 14, 2014 - 07:33 AM
If you don't own a service manual, you should
Your valve cover breather will spew oil if:
You ride at top rpm for 3min or more
You wheelie alot
You don't let all the oil drain out when you change oil, therefore your oil level goes up with each oil change
You overfill your oil
Your rings are shot
Posted July 14, 2014 - 10:58 AM
Whether or not it's anything to concern yourself with at all depends on how much drips from the tube.  Not unusual to see them belch some if you ride them hard.  A few drops along the frame, a 2 inch puddle on the floor, normal.
Manuals:
http://api.viglink.c...uals/index.aspx
http://api.viglink.c...ook.com.au/?r=0
Oil change info: http://www.thumperta...e/#entry7615908
