Best Spark Plug to use in WR450F '2011
Electrical Spark Plugs
29 replies to this topic
  • piwtorak
Posted July 11, 2014 - 01:40 PM
Hi !
I want to change the stock spark plug, I made the free mods, and I have a new complete FMF exhaust system, and boyesen quickshot 3, Jd Jetting Kit....
I read something about the NGK spark plug of Iridium is better than original
now I need know the reference and place to buy one...
thanks for help and opinions...
  • stevethe
Posted July 11, 2014 - 04:05 PM
http://www.rockymoun...idium-Sparkplug
  • GuyGraham
Posted July 12, 2014 - 12:16 AM
Iridium is better only in respect of its life
You will get no power / reliabiltiy / mpg benefit / easier starting out of it
You will however get a lighter wallet
  • SAthump
Posted July 12, 2014 - 06:02 AM
But think of the weight savings too!
  • 123devinzz1
Posted July 14, 2014 - 07:43 PM
Ive been running an e3 and idk if its just me but it seems to start a bit easier but a spark plug is a spark plug.
  • Krannie McKranface
Posted July 14, 2014 - 08:52 PM
Stick to the stock heat range no matter what brand of plug you use.
  • underground-mpyre
Posted July 16, 2014 - 05:01 AM
Everyone has told me to use a iridium spark plug for easier and better(faster) starting on these bikes. True?
Posted July 16, 2014 - 05:24 AM
Not true
Iridium is about long life, not improved performance.
  • cracker please
Posted July 16, 2014 - 05:32 AM
Brisk makes a silver electrode plug.  Silver conducts better than copper but it wears out fast.  They last maybe a tenth as long as a regular copper plug?  Maybe not even that long.  I never used them in anything, just read some stuff about them.
  • underground-mpyre
Posted July 16, 2014 - 06:05 AM
Ok, just looking for a easier starting spark plug for the Wr426(kick only) for the trails.
  • stevethe
Posted July 16, 2014 - 06:46 AM
I run them in every bike I change the plugs in. Can't hurt and they last and last.
  • underground-mpyre
Posted July 16, 2014 - 07:23 AM
Iridiums???
  • stevethe
Posted July 16, 2014 - 07:27 AM
Iridiums???
Yes Iridiums.
  • underground-mpyre
Posted July 16, 2014 - 11:12 AM
Ok thanks! So there isn't any proven plugs for easier start on kickstarts only?
  • stevethe
Posted July 16, 2014 - 01:27 PM
It's probably more your pilot jet and screw setting than anything else.
  • dg400sm
Posted July 17, 2014 - 09:20 PM
yes there is. its the heat range of the plug. depending on what kind of riding you do will depend on the heat range of the plug. if its very stop start technical riding using not a great deal of throttle you will use a hotter plug,if its wide open throttle such as supermoto or motocross you will use a colder plug. i switched to a cr9e in my yz426 because i was riding in very technical trails at not much more than half throttle. it definatlely made starting a bit easier. its all in the service manual
  • underground-mpyre
Posted July 18, 2014 - 04:59 AM
I don't have the manual, but thanks for the help.
  • GuyGraham
Posted July 18, 2014 - 10:05 AM
So, you went to a CR9E plug from the std CR8E contradicting your own advice :bonk:
A CR9E is a colder plug than an CR8E
Your easier starting probably came from the new plug rather than the heat range change
  • dg400sm
Posted July 18, 2014 - 03:31 PM
my apologies,i must have got the numbers the wrong way around,my bike has been sitting in the shed for 10 years so its 10 years since i last changed the plug. i definitely remember it made a difference as i used the hot start less. just google spark plug heat range yz426 or wr426 and you will find a wealth of information
Posted July 18, 2014 - 03:57 PM
Heat range of a spark plug is about removing heat from the insulator around the spark element
It does not change the heat of the combustion.
It changes the heat of the metal in the head, which dissapates either slowly or quickly.
If the motor is not burning all its fuel quickly enough, you put in a hotter plug to assist this
If the motor is pre-igniting it's fuel, you put in a colder plug
You determine this by analyzing the exhaust for un-burnt fuel, or aluminum particles (pre-ignition)
Changing heat range for any other reason is purely 'emotional'.
On a low compression, low-flow head like the WR, changing to anything but the stock plug will make it run worse.
