ASV F3 front brake lever
2 replies to this topic
  • jasonl20069
Posted July 10, 2014 - 09:08 AM
I brought new ASV F3 clutch and brake levers for my Yamaha WR450F 2014 which state bike specific.
Clutch instructions say you need to replace the perch but i had no problem fitting it to the oem perch,
The problem starts with the brake lever this does not fit the oem perch for the 2012-2014 model as the
master cylinder has been designed to work the brake switch, so for it to fit i will need to modify my self.[attachment=164925:2014-07-08 16.12.36.jpg][attachment=164926:2014-07-08 16.12.49.jpg][attachment=164927:2014-07-08 16.13.03.jpg][attachment=164928:2014-07-08 16.13.18.jpg]
  • GuyGraham
Posted July 10, 2014 - 10:31 AM
just swap over to a hydraulic brake light switch so you haven't got to mod the lever
  • jasonl20069
Posted July 10, 2014 - 10:42 AM
Thanks for the reply, i had the wr426f and i put a ktm hydraulic switch on it, so
that will be an option i will look at thanks again.
