2007 WR450 red exhaust after brief run up/down street
3 replies to this topic
  • jentzschman
Posted July 03, 2014 - 09:31 PM
Yes, I have seen the FAQ about this, however I still wanted to throw the question out there in relation to my jetting specs:
1) I live at~4500 feet ASL
2) I have JD jet kit installed with: red needle #4 clip position, stock 45 pilot, and 165 main.
3) All other jets are stock but I did add the thinner o-ring on the AP screw per JD instructions.
4) Grey wire mod
5) TPS unplugged
I noticed it and pretty much freaked out as this is my first thumper and right away googled it and was brought to the FAQ section on this site. I also hear it is pretty common if these WR's stay put to long and getting them moving even a little will help.
I have also found info that the pilot could be lean and or I need to adjust the fuel screw out a little.
Thank you for any help.
  • Krannie McKranface
Posted July 04, 2014 - 05:33 AM
Your jetting specs are fine
The determining factors are:
- stock header? Then it's Ti, and glows quickly
- popping upon deceleration? Turn out your fuel screw....
- still popping? you have an air leak, or a partially blocked pilot jet or pilot passage way, or a leaking hot start nut or plunger
-  Idleing still for more than 2 min? Then this will happen
  • jentzschman
Posted July 04, 2014 - 06:01 AM
I will double check those areas, thank you for your help!
  • jentzschman
Posted July 04, 2014 - 04:12 PM
I switched out the stock 45 pilot for a 48. However, I discovered that the threads on the hot start nut were a bit worn out so now I have to wait until tomorrow to get a new nut and put her all back together for a test ride.
