TPS reset
3 replies to this topic
  • jentzschman
Posted June 29, 2014 - 07:32 PM
Yep, like a dork I removed the star screw holding the TPS to the carb and as soon as it came loose I let a few expletives fly.
I have looked over the manual but have not seem anything as to how to reset it back to stock.
Any thoughts on what I can do?
Thanks.
  • Krannie McKranface
Posted June 29, 2014 - 08:05 PM
Your owners manual won't cover it
The service manual will
There are also youtube videos
  • jentzschman
Posted June 29, 2014 - 08:21 PM
I have been trying to find youtube videos about it but unless I am using wrong key words I have not been able to find any.
I do have a digital copy of the owners service manual.
I should add I heard what appeared to be a spring so I am guessing the valve on the carb got unwound. This is why I am concerned as I do not know to to reset it bcd to stock.
Edited by jentzschman, June 29, 2014 - 08:34 PM.
  • beairmo
Posted June 30, 2014 - 06:38 AM
Thanks.
What year is your bike?
My 2009 WR450F has the "stumble" or "sutter" around 5000 RPM and I was hell bent to fix it. Getting to the TPS while the carb is on the bike is a bitch. I finally gave up and removed the carb, which requires unbolting the shock and subframe.
Ultimately, I installed the DynaFS ignition which allows you to calibrate the TPS and set it with actually adjusting the sensor. You will find a lot of info if you search DynaFS.
Good Luck
