acceleration stutter?
1 reply to this topic
  • treefrog
Posted June 29, 2014 - 06:53 AM
99 wr400. I ride my bike on the street and I have noticed that during hard acceleration my bike stutters like its fuel starved. If I merge into traffic it stumbles while its under 3/4 full throttle. Not off the bottom but in the middle of a hard accel. Bike is a one kick no choke starter and runs great otherwise. I have played with main size and needle position and have it about perfect except of course for the stumble.
  • gregmanderson78
Posted June 29, 2014 - 01:04 PM
Check that your gas tank is well vented and your float arm that pushes up the needle valve in your carb bowl is bent correctly, also is the orifice behind the needle clear? either xould cause your bike to be fuel starved when under high demand
It sounds like you are sucking gas out of your carb bowl faster than it is flowing in from your tank
