08 WR 450 Hour Meter (How?)
6 replies to this topic
  • Kiwi Graham
Posted June 26, 2014 - 12:51 PM
so what to wrap the wire around?
All I can think of is to pull the cap and somehow wrap it in therebut it looks to tight a fit, How did you do yours?
Cheers
  • Krannie McKranface
Posted June 26, 2014 - 07:05 PM
You wrap as much as you can (6+ turns) around the high tension lead, as close to the cap as possible, and zip tie it in place.
You can technically wrap it anywhere around that lead, of off the coil, but it has a tendency to get snagged when you remove the tank....
  • Kiwi Graham
Posted July 13, 2014 - 03:35 PM
But I dont have a high tension lead.
At least the 08 doesn't, the coil is in the plug cap so to speak hence my question do you somehow fit it inside the cap?
Posted July 13, 2014 - 05:16 PM
You wrap it around the lead just below the cap
  • Kiwi Graham
Posted July 13, 2014 - 05:37 PM
Sweet, thanks for that
  • William1
Posted July 14, 2014 - 04:06 PM
Your bike has a COP (Coil Over Plug). Wrap as many turns as you can above the grommet that fits into the valve cover and below the point when the wire harness plugs in.
  • Kiwi Graham
Posted July 14, 2014 - 04:10 PM
Great thanks, just couldnt see how I was going to get the wire inside the COP.
