What to look for when buying wr450
4 replies to this topic
  • Dirt Squirter
Posted June 25, 2014 - 10:10 PM
I made this topic in the wrong section earlier but if u click on this link itll show you what I previously wrote... Any help will be greatly appreciated!
http://www.thumperta...st__p__11708498
  • Krannie McKranface
Posted June 26, 2014 - 05:10 AM
07-'11 are all the same
Condition is everything
You won't find any 'problems' inheirent to the bikes themselves, only in the way it was treated
https://www.youtube.... used dirt bike
  • stevethe
Posted June 26, 2014 - 06:08 AM
Bike for bike condition is everything as was just mentioned. WR450 are extremely reliable if they haven't been run out of oil and the air filter has been serviced properly. One of the best ways to look for your used bike might be to spin the rims to see if they are bent. Look at the engine side case paint for wear, ask the owner about air cleaner maintenance, pull the dip stick & check the engine oil. Push or ride the bike or look it over closely to see if it's bent from a crash. As reliable as they are it's still better to get the least ridden one, there should be plenty. Then  :ride:  the wheels off of it.
Posted June 26, 2014 - 09:04 AM
Things you should know:
Some clutch drag is normal/typical; this may cause stiffer shifting. Simple fixes are available.
These motors are NOISY, so don't be alarmed.
  • Dirt Squirter
Posted June 26, 2014 - 05:37 PM
Plenty of good info there, thanks!
